[winGRASS] m.proj fails in wingrass?
John Huddleston
jhudd at lamar.colostate.edu
Tue Jun 12 09:33:33 EDT 2001
Mike,
Check the date of your cygwin1.dll If it is the January 2001 version
then you will need to upgrade.
John Huddleston
----- Original Message -----
To: "wingrass" <wingrass at geog.uni-hannover.de>
Sent: Monday, June 11, 2001 6:41 PM
Subject: RE: [winGRASS] m.proj fails in wingrass?
> Hi Markus.
> Thanks for the suggestion.
> > > > 115, 120, 122, 126, 130, 134, 138 of ellipsoid table file
> > > > </usr/local/grass5/etc/ellipse.table> are invalid
> > > This is almost certainly a text/binary mode file read problem.
> > I have had
> > > simlar problems with other parts of Grass under CYgwin.
> > Hi,
> > maybe you are using winCVS? In past there was a severe CR/LF problem with
> > winCVS. If so, please use another CVS tool.
> I use Cygwin's CVS so hopefully this isn't the problem, but I'll look
> further into it.
> Unfortunately the format of the Cygwin path seems to affect the way files
> are treated in general, so it may be that "cvs update" in a double slash
> path gives different results to the same command in a directory entered
> using the other path format.
> When I get a chance to look further into this, I'll pass on the results
> (probably not this week).
> I have resolved similar problems by modifying the source and rebuilding -
> "open ( f, O_BINARY )", rather than "open ( f, 0 )", but unfortunately Grass
> has lots of such open calls.
> Cheers
> Mike Thomas.
> winGRASS mailing list
> winGRASS at www.geog.uni-hannover.de
> http://www.geog.uni-hannover.de/mailman/listinfo/wingrass
More information about the grass-windows
