[winGRASS] I cannot run GRASS under WinNT
Andreas Lange Andreas.Lange at Rhein-Main.de
Wed Nov 14 04:31:19 EST 2001
Alexander,
Alexander Klimuk wrote:
> I'm using WinNT. I installed cygwin to "D:\cygwin", and I can successfully run
> it, e.g. I can launch BASH command, like "ls /usr/local/grass5". Then I installed
> X-Win32 to "D:\Program Files\StarNet\X-Win32\". Then I installed xtcltk8.0.5-CYGWIN_NT-4.0-20010405-1.tar.gz.
> Then I installed GRASS binary to "D:\cygwin\usr\local\grass5\".
> I modified paths in "startxwingrass.bat". Then I lauched "startxwingrass.bat".
> Following message appeared: "Cannot find the file 'xterm' (or one of its components).
> Make sure the path ..."
> I have quastions.
> 1. I checked all my hard drives, but there is no file called "xterm". Where
> can it be found?
> 2. Original "startxwingrass.bat" contains following strings:
> set CYGWIN=C:\cygwin
> set
>  Path=%PATH%;%CYGWIN%\bin;%CYGWIN%\usr\X11R6\bin;%CYGWIN\usr\X11R6\lib;%CYGWIN%\usr\local\bin;%STARNET%;%STARLIB%
> It means that there must exist directory "C:\cygwin\usr\X11R6\bin". But there
> is no "X11R6" directory under "C:\cygwin\usr\". Why? What does it mean? When
> should be this directory created - while cygwin installation, GRASS installation,
> or in some another way?
Please read the installation documentation. You have to install the
X11R6 distribution for cygwin.
Here is the link:
http://grass.itc.it/grass5/binary/windows_cygnus/cygwin_grass50bininstall.html
Please remind that the installation of XFree86 changed a lot since i
wrote the instruction.
> 3. According to StarNet, "X-Win32 allows Windows users to connect to Linux/Unix
> servers on a local network or via the Internet.". Can I use X-Win32 to connect
> to cygwin running on my PC? If I can, how should I configure X-Win32? E.g. when
Yes, thats the purpose of StarNet X-Win in this case. Nonetheless you
need the XFree86 installation for cygwin, as X-Win is missing all the
needed client programs (e. g. xterm).
HTH,
Andreas
Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
url: http://mitglied.tripod.de/AndreasLange
mail: Andreas.Lange_at_Rhein-Main.de - A.C.Lange_at_GMX.net
More information about the grass-windows mailing list
