[winGRASS] gen: resampling continuous data
Glynn Clements
glynn.clements at virgin.net
Mon Feb 25 08:02:22 EST 2002
Matt & Kim wrote:
> oh, I just found 'r.bilinear', it almost works - unfortunately it seems to
> treat null as zero. My test elevation file changed from 355 - 2695 to 0.5 -
> 2695.
I've committed a fix to r.bilinear; it should now handle null values
correctly.
If you aren't using CVS, you can obtain the updated version of the
file (src/raster/r.bilinear/main.c) from the URL:
http://freegis.org/cgi-bin/viewcvs.cgi/~checkout~/grass/src/raster/r.bilinear/main.c?rev=1.3.4.1
Glynn Clements <glynn.clements at virgin.net>
More information about the grass-windows
