[winGRASS] compiling native windows driver
    Markus Neteler
    neteler at itc.it
    Tue Feb 26 12:16:49 EST 2002
Hi Andreas,
if you look into
 http://grass.itc.it/grass5/binary/windows_cygnus/
there is a file
 conf_cygwin.sh
with native windows driver enabled. With that conf.sh file to
run configure I successfully compiled it.
Note that the compilation is simplified:
 --enable-w11            use W11 library for Windows X11 emulation
will do everything for you. In fact, the docs need an update.
Hope this helps,
 Markus
On Tue, Feb 26, 2002 at 04:53:52PM +0100, Andreas Lange wrote:
> Hi,
> i got stuck with the compiling of the native windows driver.
> I strictly followed the description in
> src/display/devices/windows/INSTALL_WIN.
> (latest cygwin, W2K SP2, Intel PIII). I edited the head-file like the
> description, removed the OBJ.* directories and recompiled (Part 3.a of
> INSTALL_WIN). But this dies in function 'use_window':
> src/display/devices/XDRIVER/XDRIVER24/Graph_set.c:165: undefined
> reference to 'XScreenNumberOfScreen' (sorry, cut&paste does not work
> between Win and Linux).
> I am stuck here. What did i overlook? IMHO the description is not
> correct, as the paths are always referenced via
> `pwd`/bin.i686-pc-cygwin/gmake5, even if the working directory is
> somewhere deep in the grass source code.
> Do i need the -D__W98__ on Windows 2000/NT ? This is not clear to me.
> Has someone successfully compiled on W2K/NT?
> Thanks in advance,
> Andreas
> Andreas Lange, 65187 Wiesbaden, Germany, Tel. +49 611 807850
> url: http://mitglied.lycos.de/AndreasLange
> mail: Andreas.Lange_at_Rhein-Main.de - A.C.Lange_at_GMX.net
> winGRASS mailing list
> winGRASS at grass.itc.it
> http://grass.itc.it/mailman/listinfo/wingrass
Markus Neteler
ITC-irst, Istituto per la Ricerca Scientifica e Tecnologica
     Project on Predictive Models for the Environment
Via Sommarive, 18        -      38050 Povo (Trento), Italia
tel +39 0461 314 -520 (fax -591)          http://mpa.itc.it
More information about the grass-windows
