[winGRASS] problem with converting DXF to DEM
Mike Thomas mthomas at gil.com.au
Thu May 1 06:45:58 EDT 2003
Hi Knud.
Please zip up the Grass location with the data and preferably a reference to Markus' message and send it to me at:
   miketh at brisbane dot paradigmgeo dot com
cc also this address and I'll try and look at the problem before Tuesday evening.
Cheers
Mike Thomas.
  ----- Original Message -----
  To: wingrass at grass.itc.it
  Sent: Thursday, May 01, 2003 5:48 PM
  Subject: [winGRASS] problem with converting DXF to DEM
  Hei
  I have installed CYGWIN and GRASS.
  I have an DXF file with contour lines (I think), which is an export from a larger height modell.
  UTM 32, datum wgs84.
  I want to output from WinGRASSI to a compatible USGS format DEM.
  I have used a lot of time on this, but can get it to work.....
  I have tried the approach meintioned earlier by Markus Neteler (Fri, 15 Mar 01:01:24), but I dont get any results...
  Is there anyone who can take a look at this dxf and maybe explain how I make this work ???
  KTH - Norway.
URL: http://lists.osgeo.org/pipermail/grass-windows/attachments/20030501/8447ef11/attachment.html
More information about the grass-windows mailing list
