[winGRASS] Re: grass not starting
    Dilnesaw Alamirew
    dilnesaw at uni-bonn.de
    Tue Oct 10 12:12:54 EDT 2006
sorry, I managed to create a new location/mapset via command line and
abandoned the demolocation - now I do not receive any error messages
anymore but a nice interface.
However a command line setup of location/mapset via "Projection values"
does still not work with the message that the syntax is wrong.
regards,
Dilnesaw
Dilnesaw Alamirew wrote:
> Hello,
> after starting GRASS I could define a DB by using the demolocation and
> login PERMANENT but then I receive various error messages:
> 1) pop-up window:
> error in startup script
> can't read "parts(n)": no such variable while executing
> "MapCanvas::zoom_new $mon $parts(n) $part(s) $parts(e) $parts(w)
> $parts(nsres) $parts(ewres)"
> (procedure "MapCanbas::zoom_greion" lin 11
> line 40, line 11, line 69, line 30 mentioned. Unfortunately the error
> message could not be copied.
> 2) shell:
> STARTIN GRASS ....
> Warning: Attention!
> Warning: Look is not supported onWindows!
> I have a GRASS shell but no GUI.
> Second try:
> If I define a new location/mapset I get syntax error after "short
> description" promot - input not recognised, even though it is mainly
> only y or n.
> If I define a new location/mapset from a georeferenced file I get:
> Application error: channel console 2 wasn't opened for writing.
> any ideas how to solve these problems? Thanks for helping me with my
> first GRASS experience.
> regards
> Dilnesaw
More information about the grass-windows
