[winGRASS] trouble installing grass
Huidae Cho
grass4u at gmail.com
Wed Sep 20 12:28:47 EDT 2006
On Wed, Sep 20, 2006 at 03:07:40PM +0000, david welch wrote:
> HI,
> I have been attempting to launch grass on my windows machine but have been
> unable to do so.
> in one of the last steps of the installation, you are supposed to run a batch
> file in a directory, along with unzip-1.exe and wget-1.10.2b.zip
> I get the message: '\inst_grass\unzip' is not recognized as an internal or
> external command, operable program or batch file.
Where did you get that unzip-1.exe? It should be unzip.exe. Check if
you have c:\inst_grass\unzip.exe and if not, just try to copy
unzip-1.exe to c:\inst_grass\unzip.exe and run inst_grass.bat again.
Huidae
> thanks
> david
> winGRASS mailing list
> winGRASS at grass.itc.it
> http://grass.itc.it/mailman/listinfo/wingrass
More information about the grass-windows
