[winGRASS] Re: "404 Not Found" zip files when installing Wingrass
    Huidae Cho
    grass4u at gmail.com
    Wed Sep 20 12:50:29 EDT 2006
On Wed, Sep 20, 2006 at 01:33:37PM +0200, Jon Olav Vik wrote:
> Dear Huidae Cho,
> I got your address from
> http://grass.itc.it/pipermail/wingrass/2006-September/000927.html
> I tried to install Grass on Windows following the instructions on
> http://geni.ath.cx/grass.html#toc3
> on September 19. However, the following packages failed to download
> from http://superb-west.dl.sourceforge.net/sourceforge/gnuwin32/
> * pdcurses-2.6-dep.zip
> * readline-5.0-dep.zip
> * zlib-1.2.3-dep.zip
> * zip-2.31-dep.zip
> Excerpts from the wget log file follow below.
That is normal since some GnuWin32 packages don't have dependent
(*-dep.zip) packages.
> After installation with the errors mentioned above, Grass does not
> work as expected when starting c:\msys\1.0\grass.bat. First, there is
> a dialog saying "WARNING: Invalid database. Finding first valid
> directory in parent tree". Then follow the attached two error windows.
The warning message means that GRASS couldn't find any valid grass
database, which is normal because you don't have one at first try.
A real problem is the error you attached.  I don't know why that
happens. "ls -a" shouldn't exit abnormally.  The second error may be
related to the first one.  What happens if you run c:\msys\1.0\msys.bat
and type "ls -a" in the console that msys.bat just created?
Huidae
> I cannot seem to find the pdcurses-2.6-dep.zip file anywhere (haven't
> tried the others), and would appreciate any help in getting Grass to
> work on Windows XP SP2. Also, it might be good if the installer halted
> if any downloads failed.
> Thank you very much for your work.
> Sincerely,
> Jon Olav Vik
> Excerpt from wget log (adding -a outputfile to all wget commands in
> inst_grass.bat):
> --12:09:32--
> http://superb-west.dl.sourceforge.net/sourceforge/gnuwin32/pdcurses-2.6-dep.zip
>            => `pdcurses-2.6-dep.zip'
> Connecting to superb-west.dl.sourceforge.net|209.160.59.253|:80... connected.
> HTTP request sent, awaiting response... 302 Found
> Location:
> http://prdownloads.sourceforge.net/gnuwin32/pdcurses-2.6-dep.zip?download&failedmirror=superb-west.dl.sourceforge.net
> [following]
> --12:09:32--
> `pdcurses-2.6-dep.zip at download&failedmirror=superb-west.dl.sourceforge.net'
> Resolving prdownloads.sourceforge.net... 66.35.250.217
> Connecting to prdownloads.sourceforge.net|66.35.250.217|:80... connected.
> HTTP request sent, awaiting response... 404 Not Found
> 12:09:32 ERROR 404: Not Found.
> --12:09:35--
> http://superb-west.dl.sourceforge.net/sourceforge/gnuwin32/readline-5.0-dep.zip
>            => `readline-5.0-dep.zip'
> Location:
> http://prdownloads.sourceforge.net/gnuwin32/readline-5.0-dep.zip?download&failedmirror=superb-west.dl.sourceforge.net
> [following]
> --12:09:36--
> `readline-5.0-dep.zip at download&failedmirror=superb-west.dl.sourceforge.net'
> 12:09:36 ERROR 404: Not Found.
> --12:10:04--
> http://superb-west.dl.sourceforge.net/sourceforge/gnuwin32/zlib-1.2.3-dep.zip
>            => `zlib-1.2.3-dep.zip'
> Location:
> http://prdownloads.sourceforge.net/gnuwin32/zlib-1.2.3-dep.zip?download&failedmirror=superb-west.dl.sourceforge.net
> [following]
> --12:10:05--
> `zlib-1.2.3-dep.zip at download&failedmirror=superb-west.dl.sourceforge.net'
> 12:10:05 ERROR 404: Not Found.
> --12:10:10--
> http://superb-west.dl.sourceforge.net/sourceforge/gnuwin32/zip-2.31-dep.zip
>            => `zip-2.31-dep.zip'
> Location:
> http://prdownloads.sourceforge.net/gnuwin32/zip-2.31-dep.zip?download&failedmirror=superb-west.dl.sourceforge.net
> [following]
> --12:10:10--
> `zip-2.31-dep.zip at download&failedmirror=superb-west.dl.sourceforge.net'
> 12:10:10 ERROR 404: Not Found.
More information about the grass-windows
