R: [GRASS-windows] elevation data error?
Simon Watkins
handymanorama at gmail.com
Mon Jun 9 12:26:48 EDT 2008
Hi Marco,
Thanks for your very prompt reply. I just tried that but no luck alas. It
seems to me like this is being treated as a 2D raster with no elevation data
but I guess I don't really know enough about formats and such yet. This is
only a personal project, with no real urgency about it so I'll just keep
plugging away and hope I figure it out.
Simon.
On Mon, Jun 9, 2008 at 9:36 AM, <marco.pasetti at alice.it> wrote:
> Hi Simon,
> did you set the z-exag parameter?
> Since lat/long data are in decimal degrees while elevation is in meters,
> you must set the correct value for the z-exag parameter.
> The transformation from decimal degrees to meters is not univocal, because
> it depends on the geographic zone you're working on, but we can assume a
> generic (mean)transformation value and set the z-exag as follows:
> in the z-exag field type 8.9606e-6 and then enter
> I hope this helps,
> Marco
URL: http://lists.osgeo.org/pipermail/grass-windows/attachments/20080609/0d40c316/attachment.html
More information about the grass-windows
