[Gvsig_italian] "unable to access the image" and other problems
tommaso di bucchianico tommaso_db a yahoo.it
Dom 17 Feb 2008 12:29:17 PST
Hallo!
I have many problems using gvSIG 1.1 which apparently occur randomly:
1) often I cannot load raster files (all extentions) and receive the
message: "unable to access the image"
This is not a permission problem because the same files sometime I can load
and sometime I cannot...
2) Sometime the snap function doesn't work, particularly between different
layers.
3) Sometime I cannot see the pointer on the monitor, when the edit is active
4) (much less important) I work on Ubuntu 7.10 and when I active Compiz
(desktop effects), the windows "new layer", "load layer", "load project" and
all other windows are displayed white.
I have already unistalled and re-installed the software many times, whit the
file gvsig-1_1-linux-i586-withjre.bin.
The installer made always too a directory named gvSIG in /root. Is it
normal?
Finally, the uninastaller doesn't work, and I had always to delete the gvSIG
files and directories per hand.
What do I wrong??
regards,
tommaso
View this message in context: http://www.nabble.com/%22unable-to-access-the-image%22-and-other-problems-tp15532709p15532709.html
Sent from the gvSIG Italian mailing list archive at Nabble.com.
More information about the Gvsig_italian mailing list
