[gvSIG_Italian] Peakflow output
Niccolo Tubini tubini.niccolo a gmail.com
Ven 24 Ago 2018 03:44:36 PDT
Ciao a tutti,
ho lanciato il comando Peakflow e nella finestra Spatial Toolbox log leggo
questo
Process started: 2018-08-24 12:35:43
------------------------------>8----------------------------
Launching command:
C:\Program
Files\gvSIG-desktop\gvSIG-desktop-2.4.0\gvSIG\extensiones\jre\bin\java.exe
-Xmx2000m -cp
"C:\Users\Niccolo\gvSIG\installation\gvSIG\extensiones\org.hortonmachine.gvsig.base\lib\groovy-all-2.4.6.jar;C:\Users\Niccolo\gvSIG\installation\gvSIG\extensiones\org.hortonmachine.gvsig.base\lib/*;."
groovy.ui.GroovyMain
C:\Users\Niccolo\AppData\Local\Temp\hm_script_330421177113872359.groovy
(you can run the above from command line, customizing the content)
----------------------------------->8---------------------------------
Script run:
org.hortonmachine.modules.Peakflow _peakflow = new
org.hortonmachine.modules.Peakflow();
_peakflow.pA = 49.5;
_peakflow.pSat = 80;
_peakflow.pCelerity = 4;
_peakflow.outDischarge = """C:/Users/Niccolo/Documents/provaQ.csv""";
_peakflow.inTopindex =
"""C:/Users/Niccolo/gvSIG-workspace/RioSecco_5m_25832/top_index_corrected_cut.asc""";
_peakflow.inRescaledsub =
"""C:/Users/Niccolo/gvSIG-workspace/RioSecco_5m_25832/resc_dist_r100_80_sub_cut.asc""";
_peakflow.inRescaledsup =
"""C:/Users/Niccolo/gvSIG-workspace/RioSecco_5m_25832/resc_dist_r5_80_sup_cut.asc""";
_peakflow.pN = 0.32;
_peakflow.pDiffusion = 1000;
_peakflow.process();
println ""
println ""
Reading coverage: top_index_corrected_cut.asc
Finished.
Reading coverage: resc_dist_r5_80_sup_cut.asc
Finished.
Reading coverage: resc_dist_r100_80_sub_cut.asc
Finished.
Vectorizing double vectors
Sorting...
Finished.
Splitting real vectors
1 empty bins where found
Creating new matrix
Sorting...
Finished.
Creating new matrix
Sorting...
Finished.
12 empty bins where found
Creating new matrix
Peakflow launched in statistic mode...
IUH Diffusion...
Calculating diffusion...
0%...
10%...
20%...
30%...
40%...
50%...
60%...
70%...
80%...
90%...
100%...
Finished.
Calculating subsurface IUH...
10%...
20%...
30%...
40%...
50%...
60%...
70%...
80%...
90%...
100%...
Finished.
IUH Diffusion...
0%...
10%...
20%...
30%...
40%...
50%...
60%...
70%...
80%...
90%...
100%...
Finished.
Statistic Jeff...
Q calculation...
Calculating Jeff...
Calculating discharge for t < tcorr...
0%...
10%...
20%...
30%...
40%...
50%...
60%...
70%...
80%...
90%...
100%...
Finished.
Calculating discharge for t > tcorr...
0%...
10%...
20%...
30%...
40%...
50%...
60%...
70%...
80%...
90%...
100%...
Finished.
Maximum rainfall duration: 115.0
Maximum discharge value: 50.25414096383695
Process finished: 2018-08-24 12:35:52
Quando pero` apro il file .csv di output la portata massima e` pari a
37.76900478990363, la portata massima corretta e` quella nel .csv?
Riporto le prime righe del .csv
@H,date,discharge
Format,yyyy-MM-dd HH:mm,
Type,Date,
,2018-08-24 10:35,0.0
,2018-08-24 10:37,37.76900478990363
,2018-08-24 10:39,35.33001832680685
,2018-08-24 10:40,20.212508980665184
,2018-08-24 10:42,13.446104538944528
,2018-08-24 10:44,9.892880269987524
,2018-08-24 10:45,7.5939577680423245
,2018-08-24 10:47,6.011784274922036
,2018-08-24 10:49,4.929564446763167
,2018-08-24 10:50,4.122217965006686
,2018-08-24 10:52,3.531891748182115
Inoltre volevo chiedere se la durata della precipitazione riportata nel log
e` espressa in minuti.
Grazie in anticipo,
Niccolo`
Un allegato HTML รจ stato rimosso...
URL: <http://lists.osgeo.org/pipermail/gvsig-italian/attachments/20180824/c46f7738/attachment.html>
Maggiori informazioni sulla lista gvSIG-Italian
