[Liblas-devel] liblas 1.0.1 on FreeBSD64 with gcc 3.4.4
Jeff Hamann
jeff.hamann at forestinformatics.com
Wed May 27 21:10:18 EDT 2009
$ uname -a
FreeBSD bobby.forestinformatics.com 6.0-RELEASE FreeBSD 6.0-RELEASE
#2: Sun Nov 27 14:07:55 PST 2005
hamannj at bobby.forestinformatics.com:/usr/obj/usr/src/sys/GENERIC amd64
$ make check
make check-TESTS
libLAS Test Suite:
liblas::LASClassification: ..............................
liblas::LASError: ...Failed to remove '../data//lasfile_tmp.las' file
liblas::LASFile: .Failed to remove '../data//lasfile_tmp.las' file
liblas::LASHeader: ............
liblas::LASPoint: ................
liblas::LASReader: .......
liblas::LASSpatialReference: .
liblas::LASVariableRecord: ......
liblas::LASWriter: ....
liblas::guid: .......
liblas::lasreader_iterator: ......................
tests summary: ok:118
PASS: liblas_test
All 1 tests passed
(make install works fine)
and tada! Works like a charm. Excellent!
Thank you so much for a great library. Now that this seems to work
with FreeBSD 6.0, I don't need to use the 1.0.1 library.
Are there plans to move the las2ogr into the ogr library?
Jeff.
On May 27, 2009, at 4:57 PM, Mateusz Loskot wrote:
> Jeff Hamann wrote:
>> Mateusz,
>> Thank you for such a fast response. I'm stuck with FreeBSD 6.4 right
>> now, and cannot move to 7.x yet. too many dependencies...
>> I've just checked out the trunk for 1.2:
>> $ svn checkout http://liblas.org/svn/trunk/ liblas-1.2
>> Checked out revision 1289
>> $ cd liblas-1.2
>> $ ./configure
>> ./configure not found
>> $ make check
>> make: don't know how to make check. Stop
> Jeff,
> When building libLAS from SVN, you need to bootstrap it first by
> executing:
> $ ./autogen.sh
> You need to install the autotools gang, see what tools are being
> called:
> http://liblas.org/browser/trunk/autogen.sh
> It looks like the doc update request has been forgotten :-)
> http://liblas.org/ticket/90
> Best regards,
> Mateusz Loskot, http://mateusz.loskot.net
> Charter Member of OSGeo, http://osgeo.org
More information about the Liblas-devel
