[Liblas-devel] liblas 1.0.1 on FreeBSD64 with gcc 3.4.4
Jeff Hamann
jeff.hamann at forestinformatics.com
Wed May 27 22:10:52 EDT 2009
Mateusz,
I almost made it...
This works just fine (but doesn't build las2ogr)...
$ ./configure --with-boost=no
but neither of these two (live server)
$ ./configure --with-boost=no --with-gdal=/usr/local/bin/gdal-config
(sandbox)
$ ./configure --with-boost=no --with-gdal=/usr/home/hamannj/gdal-1.6.0
will build. For example,
lots of the following:
gt_wkt_srs.cpp:656: error: `Datum_North_American_Datum_1983'
undeclared (first use this function)
gt_wkt_srs.cpp:659: error: `Datum_WGS84' undeclared (first use this
function)
gt_wkt_srs.cpp:666: error: `CSVFilename' undeclared (first use this
function)
gt_wkt_srs.cpp:1924: error: `TIFFTAG_GEOTIEPOINTS' undeclared (first
use this function)
gt_wkt_srs.cpp:1965: error: `CPLFree' undeclared (first use this
function)
gt_wkt_srs.cpp:1974: error: `TIFFIsTiled' undeclared (first use this
function)
*** Error code 1
Stop in /usr/home/hamannj/liblas-1.2/src.
*** Error code 1
*** Error code 1
Stop in /usr/home/hamannj/liblas-1.2.
I've tried building with everything but boost and gdal using --with-
option-xxx=no and still can't build.
Is there a newer version of gdal/ogr I should be using? svn-trunk?
Thanks for the effort so far.
Jeff.
On May 27, 2009, at 6:10 PM, Jeff Hamann wrote:
> $ uname -a
> FreeBSD bobby.forestinformatics.com 6.0-RELEASE FreeBSD 6.0-RELEASE
> #2: Sun Nov 27 14:07:55 PST 2005 hamannj at bobby.forestinformatics.com
> :/usr/obj/usr/src/sys/GENERIC amd64
> $ make check
> make check-TESTS
> libLAS Test Suite:
> liblas::LASClassification: ..............................
> liblas::LASError: ...Failed to remove '../data//lasfile_tmp.las' file
> liblas::LASFile: .Failed to remove '../data//lasfile_tmp.las' file
> liblas::LASHeader: ............
> liblas::LASPoint: ................
> liblas::LASReader: .......
> liblas::LASSpatialReference: .
> liblas::LASVariableRecord: ......
> liblas::LASWriter: ....
> liblas::guid: .......
> liblas::lasreader_iterator: ......................
> tests summary: ok:118
> PASS: liblas_test
> All 1 tests passed
> (make install works fine)
> and tada! Works like a charm. Excellent!
> Thank you so much for a great library. Now that this seems to work
> with FreeBSD 6.0, I don't need to use the 1.0.1 library.
> Are there plans to move the las2ogr into the ogr library?
> Jeff.
> On May 27, 2009, at 4:57 PM, Mateusz Loskot wrote:
>> Jeff Hamann wrote:
>>> Mateusz,
>>> Thank you for such a fast response. I'm stuck with FreeBSD 6.4 right
>>> now, and cannot move to 7.x yet. too many dependencies...
>>> I've just checked out the trunk for 1.2:
>>> $ svn checkout http://liblas.org/svn/trunk/ liblas-1.2
>>> Checked out revision 1289
>>> $ cd liblas-1.2
>>> $ ./configure
>>> ./configure not found
>>> $ make check
>>> make: don't know how to make check. Stop
>> Jeff,
>> When building libLAS from SVN, you need to bootstrap it first by
>> executing:
>> $ ./autogen.sh
>> You need to install the autotools gang, see what tools are being
>> called:
>> http://liblas.org/browser/trunk/autogen.sh
>> It looks like the doc update request has been forgotten :-)
>> http://liblas.org/ticket/90
>> Best regards,
>> Mateusz Loskot, http://mateusz.loskot.net
>> Charter Member of OSGeo, http://osgeo.org
More information about the Liblas-devel
