[Liblas-devel] Ground Modeling with RAW LiDAR and libLAS
Stuart Edwards sedwards2 at cinci.rr.com
Fri Mar 4 13:24:43 EST 2011
On Mar 4, 2011, at 9:27 AM, Howard Butler wrote:
> On Mar 4, 2011, at 8:29 AM, francesco wrote:
>> I use GRASS quite a lot, but always thought that it would be slow on vector points. I know Brovelli and her team developed some modules, I'll check on that. Good idea to use LibLAS as "driver" to turn LAS to xyz.
> It would be much, much, much faster if someone wrote some glue between libLAS and GRASS (proposed here quite a while ago, but still not done <http://lists.osgeo.org/pipermail/grass-dev/2008-May/037687.html>).  I would guess it would be an order of magnitude faster to ingest data if you didn't have to go through text formats to do it.
This may be possible since Liblas has a las2ogr tool and GRASS uses ogr for vector input - seems there's an opportunity to script output from the former and pipe it as  input to v.in.ogr ?  Beyond my skills unfortunately ....
Stu
More information about the Liblas-devel mailing list
