[Liblas-devel] parsing xml output from lasinfo
Charles A. Cowart
charliec at sdsc.edu
Wed Mar 16 16:55:50 EDT 2011
Thanks Howard, for your quick reply!
Best Regards,
Charles
On Mar 16, 2011, at 6:32 AM, Howard Butler wrote:
> On Mar 15, 2011, at 3:54 PM, Charles A. Cowart wrote:
>> Hi,
>> Based on the schema found here (http://trac.liblas.org/wiki/
>> LASSchema), it appears that the element names from lasinfo and
>> their associated types are not defined in the schema. May I assume
>> that the lasinfo output is suitable for DOM parsing or extraction
>> with regular expressions using lasinfo output as a guide?
> Charles,
> The XML that is output is "related" to the LASSchema stuff at that
> wiki page in the sense that the schema effort was informing the
> development of the lasinfo output, but the lasinfo output is simply
> an unvalidated XML dump of the Boost property_tree that is used to
> manage the Schema entries. The Schema effort at that page is an
> attempt at coming up with something general for softwares in
> addition to libLAS to produce.
> In short, it's not quite done yet, and in the interim, you'll have
> to hack around with the lasinfo output to extract the items that you
> need.
> Sorry this is not more complete,
> Howard
More information about the Liblas-devel
