[Liblas-devel] --file-creation arg ?
Martin Isenburg martin.isenburg at gmail.com
Fri May 27 11:45:31 EDT 2011
hi.
I'm not sure how to say the same thing with Martin's tools, but I'm sure it
> has something, and I suspect it works without rewriting the file as libLAS'
> tools do (lasinfo?)
yep, howard suspects correctly. with lasinfo from LAStools you avoid the
full rewrite. the syntax - although similar - is different:
lasinfo -i lidar.las  -auto_creation
or
lasinfo -i lidar.las  -set_file_creation 8 2007
cheers,
martin @lastools
URL: http://lists.osgeo.org/pipermail/liblas-devel/attachments/20110527/c3e5a852/attachment.html
More information about the Liblas-devel mailing list
