[Liblas-devel] VS2008 64-bit biuld
Michael P. Gerlek
mpg at flaxen.com
Mon Sep 12 18:26:11 EDT 2011
You can get "vintage" boost builds here: http://boost.teeks99.com/
But yeah, you might still have to claw your way through the rest of the
dependency stack.
-mpg
> -----Original Message-----
> From: liblas-devel-bounces at lists.osgeo.org [mailto:liblas-devel-
> bounces at lists.osgeo.org] On Behalf Of Howard Butler
> Sent: Monday, September 12, 2011 3:22 PM
> To: James Hargrave
> Cc: 'liblas-devel'
> Subject: Re: [Liblas-devel] VS2008 64-bit biuld
> On Sep 12, 2011, at 4:40 PM, James Hargrave wrote:
> > Does anyone happen to have a pre-built 64-bit version of liblas using
> > VS2008 (v9)? I've built it with various settings and while liblas
> > builds when I try to include it in my project I run into compile
> > issues with the boost includes.
> > My 32-bit build works fine but not the 64 so I was hoping someone
> > might share theirs to help me track down the problem.
> Sorry, I do not.
> I presume this is because boostpro.com 64bit builds are not available for
> free? If you are building 64bit and attempting to include anything from
> OSGeo4W in the mix, that's going to be a recipe for trouble. You'll have
to
> build the entire OSGeo4W stack 64bit as well to get satisfaction, if this
is the
> scenario that's going on.
> Otherwise, hopefully a Windows compiler guru can chime in if you provide
> more detail as to what the errors are.
> Howard_______________________________________________
> Liblas-devel mailing list
> Liblas-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/liblas-devel
More information about the Liblas-devel
