[Liblas-devel] premature eof found
Helimap Postmaster postmaster at helimap.ch
Fri Apr 8 03:12:47 PDT 2016
Hello Mateusz,
Oh that's sad...
liblas is on the ubuntu repositories which is a point in favor and it is
also used in many applications like cloudcompare, which means there are a
lot of examples and use cases.
pdal is a bit overkill if I only want las I/O. I've fiddled with it a
little bit. It is a superb framework, but isn't it too much if I just want
to read and write a las cloud to/from a buffer? Also, there aren't that
many c++ examples for I/O and there's no way to read into a container, I
would have to develop a pointtable myself and I won't have the time to get
deep in it unfortunately...
I've also tried LASlib. Their code is obscure and the licensing more
obscure.
Well, maybe I should give pdal another try...
On Fri, Apr 8, 2016 at 12:00 PM, Mateusz Loskot <mateusz at loskot.net> wrote:
> On 8 April 2016 at 11:52, Helimap Postmaster <postmaster at helimap.ch>
> wrote:
> > Nobody has had this problem? Or an idea of what might've going on?
> libLAS has been deprecated and is not actively maintained [1].
> So, please don't expect prompt responses or fixes at all.
> Instead, consider PDAL.
> [1] https://lists.osgeo.org/pipermail/liblas-devel/2015-August/001605.html
> [2] http://www.pdal.io/
> Mateusz Loskot, http://mateusz.loskot.net
URL: <http://lists.osgeo.org/pipermail/liblas-devel/attachments/20160408/a26494ec/attachment.html>
More information about the Liblas-devel mailing list
