[Liblas-devel] premature eof found
Martin Isenburg martin.isenburg at gmail.com
Fri Apr 8 03:21:24 PDT 2016
Our LASlib code may be obscure (yet some like its simplicity) but
the LASlib license is certainly not.
http://github.com/LAStools/LAStools/blob/master/LICENSE.txt
http://lastools.org/LICENSE.txt
It's standard LGPL 2.1 ... not obscure at all.
Regards from the Philippines,
Martin @rapidlasso
On Fri, Apr 8, 2016 at 12:12 PM, Helimap Postmaster <postmaster at helimap.ch>
wrote:
> Hello Mateusz,
> Oh that's sad...
> liblas is on the ubuntu repositories which is a point in favor and it is
> also used in many applications like cloudcompare, which means there are a
> lot of examples and use cases.
> pdal is a bit overkill if I only want las I/O. I've fiddled with it a
> little bit. It is a superb framework, but isn't it too much if I just want
> to read and write a las cloud to/from a buffer? Also, there aren't that
> many c++ examples for I/O and there's no way to read into a container, I
> would have to develop a pointtable myself and I won't have the time to get
> deep in it unfortunately...
> I've also tried LASlib. Their code is obscure and the licensing more
> obscure.
> Well, maybe I should give pdal another try...
> On Fri, Apr 8, 2016 at 12:00 PM, Mateusz Loskot <mateusz at loskot.net>
> wrote:
>> On 8 April 2016 at 11:52, Helimap Postmaster <postmaster at helimap.ch>
>> wrote:
>> > Nobody has had this problem? Or an idea of what might've going on?
>> libLAS has been deprecated and is not actively maintained [1].
>> So, please don't expect prompt responses or fixes at all.
>> Instead, consider PDAL.
>> [1]
>> https://lists.osgeo.org/pipermail/liblas-devel/2015-August/001605.html
>> [2] http://www.pdal.io/
>> Mateusz Loskot, http://mateusz.loskot.net
> Liblas-devel mailing list
> Liblas-devel at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/liblas-devel
URL: <http://lists.osgeo.org/pipermail/liblas-devel/attachments/20160408/2ef45967/attachment.html>
More information about the Liblas-devel mailing list
