[Liblas-devel] premature eof found
Helimap Postmaster
postmaster at helimap.ch
Fri Apr 8 03:33:45 PDT 2016
Hello Martin,
I was maybe misquoting the article Mateusz linked, sorry for that.
About the code, I find obscure that the variables in LASpoint are public
but you have setters. I can change have_rgb but the point will still not
'have' rgb. I am also worried about the performance issue of creating
points for writing. In my use case I change the point type from xyz to
xyzrgb and apparently that means I have to init a new point. Otherwise it
doesn't have the writer.
I'm concerned because the init does clean the point and then it re-writes
it. When dealing with trillions of points... I couldn't find how to
'change' a xyz point type to rgb.
I would suggest also having defines or const ints with the point types, I
couldn't find them.
Is there a way to do it that I am missing?
Other than that, LASlib was the one that most suited my needs and played
nice with windows.
Cheers,
Pol
ps. there's a thread I've posted in the lastools list about this, entitled *set
rgb with laslib*
On Fri, Apr 8, 2016 at 12:21 PM, Martin Isenburg <martin.isenburg at gmail.com>
wrote:
> Hi,
> Our LASlib code may be obscure (yet some like its simplicity) but
> the LASlib license is certainly not.
> http://github.com/LAStools/LAStools/blob/master/LICENSE.txt
> http://lastools.org/LICENSE.txt
> It's standard LGPL 2.1 ... not obscure at all.
> Regards from the Philippines,
> Martin @rapidlasso
> On Fri, Apr 8, 2016 at 12:12 PM, Helimap Postmaster <postmaster at helimap.ch
> > wrote:
>> Hello Mateusz,
>> Oh that's sad...
>> liblas is on the ubuntu repositories which is a point in favor and it is
>> also used in many applications like cloudcompare, which means there are a
>> lot of examples and use cases.
>> pdal is a bit overkill if I only want las I/O. I've fiddled with it a
>> little bit. It is a superb framework, but isn't it too much if I just want
>> to read and write a las cloud to/from a buffer? Also, there aren't that
>> many c++ examples for I/O and there's no way to read into a container, I
>> would have to develop a pointtable myself and I won't have the time to get
>> deep in it unfortunately...
>> I've also tried LASlib. Their code is obscure and the licensing more
>> obscure.
>> Well, maybe I should give pdal another try...
>> On Fri, Apr 8, 2016 at 12:00 PM, Mateusz Loskot <mateusz at loskot.net>
>> wrote:
>>> On 8 April 2016 at 11:52, Helimap Postmaster <postmaster at helimap.ch>
>>> wrote:
>>> > Nobody has had this problem? Or an idea of what might've going on?
>>> libLAS has been deprecated and is not actively maintained [1].
>>> So, please don't expect prompt responses or fixes at all.
>>> Instead, consider PDAL.
>>> [1]
>>> https://lists.osgeo.org/pipermail/liblas-devel/2015-August/001605.html
>>> [2] http://www.pdal.io/
>>> Mateusz Loskot, http://mateusz.loskot.net
>> Liblas-devel mailing list
>> Liblas-devel at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/liblas-devel
URL: <http://lists.osgeo.org/pipermail/liblas-devel/attachments/20160408/d8c97053/attachment.html>
More information about the Liblas-devel
