[Live-demo] Re: overview images?
Hamish
hamish_b at yahoo.com
Sun Aug 1 23:13:24 EDT 2010
Jody wrote:
> Sorted out the issue; depending on the version of sphinx used the use of :
> .. image:: images/screenshots/1024x768/udig-overview.png
> :scale: 50 %
> :alt: udig workshop
> :align: right
> Will result in a warning and the image won't be used.
> Simply remove the "%" and everything will work...
> :scale: 50
> :alt: udig workshop
> :align: right
> If this change can be made to the RST files everything
> should be fine.
fwiw the version in Ubuntu 10.04 doesn't mind the "%" sign, and the "%"
sign is officially optional in the reSt spec. (I've no idea about the
timing, I suspect that sphinx is playing catch up instead of reSt adding
new features, but that's just a guess)
Rather than removing the % signs in svn, I suggest if you want to try
running the sphinx build outside of the xU 10.04 environment that you
strip away those % manually+locally:
cd doc/overview
sed -i -e 's/:scale:\([^%]*\) %/:scale:\1/' *.rst
regards,
Hamish
More information about the Live-demo
