[Live-demo] osgeo-live version 4.0alpha6 available for download
Hamish
hamish_b at yahoo.com
Sun Jul 4 02:09:38 EDT 2010
Cameron wrote:
> although for some reason some of the desktop folders are not
> available and you need to use the pull down Application list
> to find applications (or the command line).
should be fixed by r3848. (Xfce dir structure changed since Karmic)
AFAICT there's nothing wrong with GpsDrive's install script; some of the
build tools disappeared. perhaps somehow setdown.sh got run before all
scripts were complete? shrug.
* load_postgis.sh's osm2pgsql will need to be modified due to a chicken
and egg problem: Barcelona.osm is not downloaded until install_osm.sh,
which runs after install_postgis.sh. Suggest to move the osm2pgsql stuff
into install_osm.sh; if possible setting up the PostGIS DB in a way
compatible with Ross Scanlon's instructions here:
https://sourceforge.net/apps/mediawiki/gpsdrive/index.php?title=Setting_up_Mapnik
so that the resulting OSM DB can be accessed live from within GpsDrive &
then we can drop the pre-rendered sample data for that. (was 73mb for
Sydney)
also AFAIK osm2gpsql is smart enough to read planet.osm.bz2 files directly,
no need to unbzip them first.
Hamish
More information about the Live-demo
