[Lizmap-de] Probleme mit Lizmap-Konfiguration
Christiane Enderle
enderlec at staff.uni-marburg.de
Di Jul 1 08:09:28 PDT 2025
Hi Etienne,
thanks a lot for looking at the german lizmap-mailinglist!
I see the landing page of lizmap with two demo projects (when logged in
there are three), but I can't load and display the maps.
In the lizmapConfig.ini.php I have changed the URL for QGIS server to
https://myserver/cgi-bin/qgis_mapserv.fcgi? ("myserver" in this mail
replaces the actual server name; remark "https" - the QGIS server runs
with port 443) and the result in the administration panel, server
information, is the following:
QGIS Server
QGIS Server is correctly installed and returns the expected response for
OGC requests.
*We cannot get the details about your QGIS Server installation (version,
plugins, etc.).*
You must check that the following steps are done :
1. *QGIS Server* is above or equal to *3.28 is 3.40.8
2. The *Lizmap QGIS server plugin* is installed on the server with a
version above or equal to *2.13.0 is true
3. The URL to reach QGIS server is *correct* in your administration
panel probably true since it says above "QGIS Server is correctly
installed..."
4. The URL to reach the Lizmap API on QGIS Server is *correct* in your
administration panel, if you use Py-QGIS-Server maybe the URL is
wrong, but I don't know how to access this tag or where I can
modify it and what is correct. I don't use py-qgis-server.
5. Your Lizmap Web Client *logs* does not contain any warnings about
reaching QGIS server see below
6. The *environment variable* about the *Lizmap server plugin*
described in the documentation link below is correctly set in your
configuration The conf-file in /etc/apache2/sites-available contains
the tag FcgidInitialEnv QGIS_SERVER_LIZMAP_REVEAL_SETTINGS True
7. Your QGIS server *logs* does not contain any warnings about the
Lizmap server plugin (at QGIS server startup and when loading this
webpage). You might need to increase debug level.
The errors.log says:
2025-07-01 13:44:07 137.248.191.3 error The HTTP request ended
with an error. HTTP code 500. →
https://myserver/cgi-bin/qgis_mapserv.fcgi?/lizmap/server.json
https://myserver/cgi-bin/qgis_mapserv.fcgi?service=WMS&request=GetCapabilities
The lizmap-admin.log says:
2025-07-01 13:44:07 137.248.191.3 lizmapadmin An HTTP request
ended with an error, please check the main error log. HTTP code 500.
2025-07-01 13:44:07 137.248.191.3 lizmapadmin QGIS server
minimum 3.28 and Lizmap QGIS server plugin minimum 2.13.0 need to be
installed and configured correctly. Your QGIS server couldn't be reached
correctly with the given URL "https://myserver/cgi-bin/qgis_mapserv.fcgi?".
The qgis.demo.error.log says:
<ServerException>Project file error. For OWS services: please provide a
SERVICE and a MAP parameter pointing to a valid QGIS project
file</ServerException>
So I changed the QGIS Server URL to
https://myserver/cgi-bin/qgis_mapserv.fcgi?SERVICE=WMS&MAP=/var/www/lizmap-web-client-3.8.11/lizmap/lizmap-modules/lizmapdemo/qgis-projects/demoqgis/montpellier.qgs
But it didn't work.
I suppose, there are several mistakes in the configuration. For example
I don't know, which files must be accessible by www-data. One of our
certificate files for https is protected by a passphrase. I have no idea
if this has an impact.
Any hint might be helpful. Thank you very much in advance.
Best wishes,
Christiane
Am 26.06.2025 um 18:21 schrieb Etienne Trimaille via Lizmap-de:
> Hi,
> In your administration panel, visit the "Lizmap configuration" page to
> set the correct URL for QGIS server.
> I don't think it's related to Apache/Nginx, at this step.
> Sorry for the English, just looking at the screenshot quickly ;-)
> On 26/06/2025 17:22, Christiane Enderle via Lizmap-de wrote:
>> Hallo zusammen,
>> ich habe unter Ubuntu 22 QGIS-Server 3.40.8, apache2 und Lizmap
>> QGIS-Server Plugin 3.8.11 installiert. (Mit py-qgis-server konnte ich
>> mich nicht anfreunden). Die Lizmap-Website wird angezeigt. Aber bei
>> den Demo-Beispielen können die Karten nicht geladen werden. Wenn ich
>> mich als admin einlogge, erhalte ich in der Server-Information die
>> Meldung (siehe Anhang Serverinfo_lizmap.png):
>> QGIS Server is not correctly installed in your server or the URL for
>> OGC requests given in Lizmap configuration is not correct.
>> Die Datei lizmap.conf ist in der Anleitung der Lizmap-Doku leider nur
>> für nginx angegeben. Deshalb habe ich sie mir mit einer KI für
>> apache2 ummodeln lassen. Möglicherweise ist da etwas falsch. Aber
>> was? Der Inhalt meiner lizmap.conf ist im Anhang 2025_06_26 17h
>> lizmap.conf.txt (die IP-Adresse bei Servername und hinter fcgi habe
>> ich für diese Frage mit Text ersetzt).
>> Ich würde mich freuen, wenn mir jemand weiterhelfen könnte, auch wenn
>> wir schon bald unser Online-Treffen haben.
>> Schöne Grüße,
>> Christiane Enderle
>> Christiane Enderle (MSc GIS)
>> Fachbereich Geographie
>> Zentrum für Geomatik und Mediengestaltung
>> <https://www.uni-marburg.de/de/fb19/fachbereich/infrastruktur/kartographie>
>> Deutschhausstr. 10
>> 35037 Marburg
>> Tel. 06421-2822179
>> Fax 06421-2828950
> Etienne Trimaille
> Géomaticien
> www.3liz.com <http://www.3liz.com>
> *Tel.* 06 12 93 11 39
> *Bureau*
> 31, rue de l'Argenterie
> 34000 Montpellier
> *Siège social*
> 73, allée Kleber
> Boulevard de Strasbourg
> 34000 Montpellier
Deutschhausstr. 10
35037 Marburg
Tel. 06421-2822179
Fax 06421-2828950
-------------- nächster Teil --------------
Ein Dateianhang mit HTML-Daten wurde abgetrennt...
URL: <http://lists.osgeo.org/pipermail/lizmap-de/attachments/20250701/5f9ad870/attachment.htm>
Mehr Informationen über die Mailingliste Lizmap-de
