[Mapbender-commits] r3719 -
trunk/mapbender/resources/locale/fr_FR/LC_MESSAGES
svn_mapbender at osgeo.org
Sat Mar 14 08:34:49 EDT 2009
Author: astrid_emde
Date: 2009-03-14 08:34:49 -0400 (Sat, 14 Mar 2009)
New Revision: 3719
trunk/mapbender/resources/locale/fr_FR/LC_MESSAGES/Mapbender.po
new translations added
Modified: trunk/mapbender/resources/locale/fr_FR/LC_MESSAGES/Mapbender.po
--- trunk/mapbender/resources/locale/fr_FR/LC_MESSAGES/Mapbender.po 2009-03-14 12:34:30 UTC (rev 3718)
+++ trunk/mapbender/resources/locale/fr_FR/LC_MESSAGES/Mapbender.po 2009-03-14 12:34:49 UTC (rev 3719)
@@ -3,19 +3,18 @@
# This file is distributed under the same license as the PACKAGE package.
# FIRST AUTHOR <EMAIL at ADDRESS>, YEAR.
+#, fuzzy
msgid ""
msgstr ""
-"Project-Id-Version: VERSION FINALE\n"
+"Project-Id-Version: PACKAGE VERSION\n"
"Report-Msgid-Bugs-To: \n"
-"POT-Creation-Date: 2007-07-29 22:30+0200\n"
-"PO-Revision-Date: 2009-01-29 23:17+0100\n"
-"Last-Translator: Matthieu Rigal GeoRezo <tgae0607 at free.fr>\n"
-"Language-Team: RapidEye <rigal at rapideye.de>\n"
+"POT-Creation-Date: 2009-03-14 13:32+0100\n"
+"PO-Revision-Date: YEAR-MO-DA HO:MI+ZONE\n"
+"Last-Translator: FULL NAME <EMAIL at ADDRESS>\n"
+"Language-Team: LANGUAGE <LL at li.org>\n"
"MIME-Version: 1.0\n"
"Content-Type: text/plain; charset=UTF-8\n"
"Content-Transfer-Encoding: 8bit\n"
-"X-Poedit-Language: French\n"
-"X-Poedit-Country: FRANCE\n"
#: printPDF.conf:13
msgid "Download: Map as PDF..."
@@ -50,28 +49,49 @@
msgstr "Notes"
#: printPDF.conf:73
-msgid "This copy has been automatically generated and is thus not valid without signature."
-msgstr "Cette copie a été générée automatiquement et est ainsi non valide sans signature."
+msgid ""
+"This copy has been automatically generated and is thus not valid without "
+"signature."
+msgstr ""
+"Cette copie a été générée automatiquement et est ainsi non valide sans "
+"signature."
#: printPDF.conf:74
-msgid "This copy is protected by law (Par. 3 Abs. 1 VermKatG NW). It can be duplicated, modified, published or be passed to third parties only in agreement with"
-msgstr "Cette copie est protégée par la loi (Allemagne, § 3 Abs. 1 VermKatG NW). Elle ne peut être copiée, modifiée, publiée ou transmise à des parties tierces sans l'accord de"
+msgid ""
+"This copy is protected by law (Par. 3 Abs. 1 VermKatG NW). It can be "
+"duplicated, modified, published or be passed to third parties only in "
+"agreement with"
+msgstr ""
+"Cette copie est protégée par la loi (Allemagne, § 3 Abs. 1 VermKatG NW). "
+"Elle ne peut être copiée, modifiée, publiée ou transmise à des parties "
+"tierces sans l'accord de"
#: printPDF.conf:75
-msgid "the publisher, except duplicates and modifications aimed at internal use of government agencies or private use."
-msgstr "l'éditeur, à l'exception des copies et modifications destinées à l'usage interne d'agences gouvernementales ou à usage privé."
+msgid ""
+"the publisher, except duplicates and modifications aimed at internal use of "
+"government agencies or private use."
+msgstr ""
+"l'éditeur, à l'exception des copies et modifications destinées à l'usage "
+"interne d'agences gouvernementales ou à usage privé."
#: printPDF.conf:
msgid "This copy is protected by law (Par. 3 Abs. 1 VermKatG NW)."
-msgstr "Cette copie est protégée par la loi (Allemagne, § 3 Abs. 1 VermKatG NW)."
+msgstr ""
+"Cette copie est protégée par la loi (Allemagne, § 3 Abs. 1 VermKatG NW)."
#: printPDF.conf:
-msgid "It can be duplicated, modified, published or be passed to third parties only in"
-msgstr "Elle ne peut être copiée, modifiée, publiée ou transmise à des parties tierces "
+msgid ""
+"It can be duplicated, modified, published or be passed to third parties only "
+"in"
+msgstr ""
+"tierces "
#: printPDF.conf:
msgid "agreement with the publisher except duplicates and modifications"
-msgstr "sans l'accord de l'éditeur, à l'exception des copies et modifications destinées"
+msgstr ""
+"sans l'accord de l'éditeur, à l'exception des copies et modifications "
+"destinées"
#: printPDF.conf:
msgid "aimed at internal use of government agencies or private use."
@@ -281,31 +301,144 @@
msgid "Invalid box!"
msgstr "Rectangle non valide!"
-#: /html/mod_treefolder2.php:56
+#: /html/mod_treefolder2.php:56 http/html/mod_treefolderPlain.php:34
msgid "Toggles the visibility of this service"
msgstr "Active/désactive la visibilité du service"
-#: /html/mod_treefolder2.php:57
+#: /html/mod_treefolder2.php:57 http/html/mod_treefolderPlain.php:35
msgid "Toggles the queryability of this service"
msgstr "Active/désactive la fonction d'interrogation sélective du service"
-#: /html/mod_treefolder2.php:58
+#: /html/mod_treefolder2.php:58 http/html/mod_treefolderPlain.php:36
msgid "Opens the layer context menu"
msgstr "Ouvre le menu contextuel de la couche"
-#: /html/mod_treefolder2.php:59
+#: /html/mod_treefolder2.php:59 http/html/mod_treefolderPlain.php:37
msgid "Opens the WMS context menu"
msgstr "Ouvre le menu contextuel du WMS"
-#: /html/mod_treefolder2.php:60
+#: /html/mod_treefolder2.php:60 http/html/mod_treefolderPlain.php:38
msgid "Removes the selected WMS"
msgstr "Supprime le WMS sélectionné"
-#: /html/mod_treefolder2.php:61
+#: /html/mod_treefolder2.php:61 http/html/mod_treefolderPlain.php:39
msgid "Moves the selection up"
msgstr "Déplace la sélection vers le haut"
-#: /html/mod_treefolder2.php:62
+#: /html/mod_treefolder2.php:62 http/html/mod_treefolderPlain.php:40
msgid "Moves the selection down"
msgstr "Déplace la sélection vers le bas"
+#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:327
+msgid "WMS name"
+msgstr ""
+#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:328
+msgid "WMS abstract"
+msgstr ""
+#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:329
+msgid "Please select a WMS"
+msgstr ""
+#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:330
+msgid "Please select an application"
+msgstr ""
+#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:331
+msgid "Please select a group"
+msgstr ""
+#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:332
+msgid "group abstract"
+msgstr ""
+#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:333
+msgid "group name"
+msgstr ""
+#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:334
+msgid "application abstract"
+msgstr ""
+#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:335
+msgid "application name"
+msgstr ""
+#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:336
+msgid "no result"
+msgstr ""
+#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:342
+msgid "Add WMS"
+msgstr ""
+#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:343
+msgid "Enter a Capabilities-URL of a WMS or select one or more WMS from list."
+msgstr ""
+#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:344
+msgid ""
+"Notice: Be aware of the scale hints. Possibly you need to zoom in to display "
+"the added service."
+msgstr ""
+#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:350
+msgid "Capabilities-URL"
+msgstr ""
+#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:362
+msgid "List all WMS"
+msgstr ""
+#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:363
+msgid "List WMS by Group"
+msgstr ""
+#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:364
+msgid "List WMS by Application"
+msgstr ""
+#: http/javascripts/mod_addWMSfromfilteredList_ajax.php:374
+msgid "Loading WMS"
+msgstr ""
+#: http/html/mod_treefolderPlain.php:33
+msgid "(De)activate this service"
+msgstr ""
+#: http/html/mod_treefolderPlain.php:144
+msgid "Move up"
+msgstr ""
+#: http/html/mod_treefolderPlain.php:145
+msgid "Move down"
+msgstr ""
+#: http/html/mod_treefolderPlain.php:146
+msgid "Remove"
+msgstr ""
+#: http/html/mod_treefolderPlain.php:147
+msgid "Opacity up"
+msgstr ""
+#: http/html/mod_treefolderPlain.php:148
+msgid "Opacity down"
+msgstr ""
+#: http/html/mod_treefolderPlain.php:149
+msgid "Information"
+msgstr ""
+#: http/html/mod_treefolderPlain.php:150 http/html/mod_treefolderPlain.php:152
+msgid "Zoom"
+msgstr ""
+#: http/html/mod_treefolderPlain.php:151
+msgid "Hide menu"
+msgstr ""
+#: ../http/php/mb_listGUIs.php:54
+msgid "available Applications"
+msgstr ""
More information about the Mapbender_commits
