[Mapbender-commits] r10134 - trunk/mapbender/http/php
svn_mapbender at osgeo.org
Tue Jun 4 14:24:14 PDT 2019
Author: armin11
Date: 2019-06-04 14:24:13 -0700 (Tue, 04 Jun 2019)
New Revision: 10134
Added:
trunk/mapbender/http/php/mod_activateUserAccount.php
Simple script to allow activation of a user account after self registration
Added: trunk/mapbender/http/php/mod_activateUserAccount.php
--- trunk/mapbender/http/php/mod_activateUserAccount.php (rev 0)
+++ trunk/mapbender/http/php/mod_activateUserAccount.php 2019-06-04 21:24:13 UTC (rev 10134)
@@ -0,0 +1,98 @@
+<?php
+# $Id:
+# http://www.mapbender.org/index.php
+# This program is free software; you can redistribute it and/or modify
+# it under the terms of the GNU General Public License as published by
+# the Free Software Foundation; either version 2, or (at your option)
+# any later version.
+# This program is distributed in the hope that it will be useful,
+# but WITHOUT ANY WARRANTY; without even the implied warranty of
+# MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
+# GNU General Public License for more details.
+# You should have received a copy of the GNU General Public License
+# along with this program; if not, write to the Free Software
+# Foundation, Inc., 59 Temple Place - Suite 330, Boston, MA 02111-1307, USA.
+require_once(dirname(__FILE__)."/../../core/globalSettings.php");
+//require_once(dirname(__FILE__)."/../classes/class_user.php");
+$returnObject = new stdClass();
+if (defined("DJANGO_PORTAL") && DJANGO_PORTAL == true) {
+ if($_SERVER["HTTPS"] != "on") {
+ $loginRedirectUrl = "http://".$_SERVER['HTTP_HOST']."/login/";
+ $registerRedirectUrl = "http://".$_SERVER['HTTP_HOST']."/register/";
+ } else {
+ $loginRedirectUrl = "https://".$_SERVER['HTTP_HOST']."/login/";
+ $registerRedirectUrl = "https://".$_SERVER['HTTP_HOST']."/register/";
+} else {
+ $loginRedirectUrl = LOGIN;
+ $registerRedirectUrl = $loginRedirectUrl;
+if (isset($_REQUEST["activationKey"]) & $_REQUEST["activationKey"] != "") {
+ $testMatch = $_REQUEST["activationKey"];
+ $pattern = '/^([a-z]|[0-9])*$/';
+ if (!preg_match($pattern,$testMatch)){
+ echo 'Parameter <b>activationKey</b> is not valid.<br/>';
+ die();
+ $activationKey = $testMatch;
+ $testMatch = NULL;
+//select account
+$sql = "SELECT mb_user_id FROM mb_user WHERE activation_key = $1";
+$v = array($activationKey);
+$t = array('s');
+$res = db_prep_query($sql, $v, $t);
+if(db_numrows($res) == 0){
+ $e = new mb_exception("php/mod_activateUserAccount.php: user with requested activation_key not found in mapbender database!");
+ $returnObject->success = false;
+ $returnObject->help = "mod_activateUserAccount.php";
+ $returnObject->error->message = "php/mod_activateUserAccount.php: user with requested activation_key not found in mapbender database!";
+ $returnObject->error->{__type} = "Object not found";
+ header('Content-Type: application/json');
+ echo json_encode($this->returnObject);
+ //redirect to register
+ header("Location: ".$registerRedirectUrl);
+ die();
+} else {
+ $row = db_fetch_assoc($res);
+ if ($row['is_active'] == 't') {
+ $e = new mb_exception("php/mod_activateUserAccount.php: User account already activated!");
+ $returnObject->error->message = "php/mod_activateUserAccount.php: User account already activated!";
+ //redirect to login?
+ header("Location: ".$loginRedirectUrl);
+ die();
+ } else {
+ $sql = "UPDATE mb_user SET is_active = true WHERE activation_key = $1";
+ $v = array($activationKey);
+ $t = array('s');
+ $res = db_prep_query($sql, $v, $t);
+ if (!$res) {
+ $e = new mb_exception("php/mod_activateUserAccount.php: Could not activate user account!");
+ $returnObject->error->message = "php/mod_activateUserAccount.php: Could not activate user account!";
+ die();
+ } else {
+ $e = new mb_exception("php/mod_activateUserAccount.php: User account successfully activated!");
+ $returnObject->success = true;
+ unset($returnObject->error);
+ //redirect to login page
+ die();
More information about the Mapbender_commits
