[Mapbender-commits] r10135 - trunk/mapbender/http/php
svn_mapbender at osgeo.org
Wed Jun 5 01:02:32 PDT 2019
Author: armin11
Date: 2019-06-05 01:02:32 -0700 (Wed, 05 Jun 2019)
New Revision: 10135
trunk/mapbender/http/php/mod_layerISOMetadata.php
some fixes
Modified: trunk/mapbender/http/php/mod_layerISOMetadata.php
--- trunk/mapbender/http/php/mod_layerISOMetadata.php 2019-06-04 21:24:13 UTC (rev 10134)
+++ trunk/mapbender/http/php/mod_layerISOMetadata.php 2019-06-05 08:02:32 UTC (rev 10135)
@@ -28,6 +28,19 @@
require_once(dirname(__FILE__)."/../classes/class_owsConstraints.php");
require_once(dirname(__FILE__)."/../classes/class_qualityReport.php");
+//check for absolute url
+if (defined("MAPBENDER_PATH") && MAPBENDER_PATH != '') {
+ $mapbenderUrl = MAPBENDER_PATH;
+} else {
+ if(!empty($_SERVER['HTTPS']) && $_SERVER['HTTPS']!='off') {
+ $mapbenderUrl = "https://".$_SERVER['HTTP_HOST']."/mapbender";
+ $protocol = "https";
+ } else {
+ $mapbenderUrl = "http://".$_SERVER['HTTP_HOST']."/mapbender";
+ $protocol = "http";
$con = db_connect(DBSERVER,OWNER,PW);
db_select_db(DB,$con);
@@ -94,6 +107,7 @@
function fillISO19139($iso19139, $recordId) {
global $wmsView;
global $admin;
+ global $mapbenderUrl;
//read out relevant information from mapbender database:
if ($wmsView != '') {
$sql = "SELECT * ";
@@ -462,11 +476,11 @@
$MD_BrowseGraphic=$iso19139->createElement("gmd:MD_BrowseGraphic");
$fileName=$iso19139->createElement("gmd:fileName");
$fileName_cs=$iso19139->createElement("gco:CharacterString");
- if (defined("MAPBENDER_PATH") && MAPBENDER_PATH != '') {
+ /*if (defined("MAPBENDER_PATH") && MAPBENDER_PATH != '') {
} else {
$mapbenderUrl = "http://www.geoportal.rlp.de/mapbender";
$previewFilenameText = $iso19139->createTextNode($mapbenderUrl."/geoportal/preview/".$mapbenderMetadata['layer_id']."_layer_map_preview.jpg"); //TODO use constant for absolute path
$fileName_cs->appendChild($previewFilenameText);
$fileName->appendChild($fileName_cs);
@@ -707,7 +721,7 @@
//Check if anonymous user has rights to access this layer - if not ? which resource should be advertised? TODO
//if ($hasPermission) {
- $gmd_URLText=$iso19139->createTextNode("http://".$_SERVER['HTTP_HOST']."/mapbender/php/wms.php?inspire=1&layer_id=".$mapbenderMetadata['layer_id']."&REQUEST=GetCapabilities&SERVICE=WMS");
+ $gmd_URLText=$iso19139->createTextNode($mapbenderUrl."/php/wms.php?inspire=1&layer_id=".$mapbenderMetadata['layer_id']."&withChilds=1&REQUEST=GetCapabilities&SERVICE=WMS");
/*else {
$serverWithOutPort80 = str_replace(":80","",$_SERVER['HTTP_HOST']);//fix problem when metadata is generated thru curl invocations
@@ -738,19 +752,19 @@
switch ($row_metadata['origin']) {
case 'capabilities':
$operatesOn=$iso19139->createElement("srv:operatesOn");
- $operatesOn->setAttribute("xlink:href", "http://".$_SERVER['HTTP_HOST']."/mapbender/php/mod_dataISOMetadata.php?outputFormat=iso19139&id=".$row_metadata['uuid']);
+ $operatesOn->setAttribute("xlink:href", $mapbenderUrl."/php/mod_dataISOMetadata.php?outputFormat=iso19139&id=".$row_metadata['uuid']);
$operatesOn->setAttribute("uuidref", $uniqueResourceIdentifierCodespace.$row_metadata['datasetid']);
$SV_ServiceIdentification->appendChild($operatesOn);
break;
case 'metador':
- $operatesOn->setAttribute("xlink:href", "http://".$_SERVER['HTTP_HOST']."/mapbender/php/mod_dataISOMetadata.php?outputFormat=iso19139&id=".$row_metadata['uuid'].'#spatial_dataset_'.md5($row_metadata['uuid']));
+ $operatesOn->setAttribute("xlink:href", $mapbenderUrl."/php/mod_dataISOMetadata.php?outputFormat=iso19139&id=".$row_metadata['uuid'].'#spatial_dataset_'.md5($row_metadata['uuid']));
$operatesOn->setAttribute("uuidref", $uniqueResourceIdentifierCodespace.$row_metadata['uuid']);
break;
case 'external':
break;
@@ -786,10 +800,10 @@
else {
- $gmd_URLText=$iso19139->createTextNode("https://".$_SERVER['HTTP_HOST']."/http_auth/".$mapbenderMetadata['layer_id']."?REQUEST=GetCapabilities&SERVICE=WMS");
+ $gmd_URLText=$iso19139->createTextNode("https://".$_SERVER['HTTP_HOST']."/http_auth/".$mapbenderMetadata['layer_id']."?withChilds=1&REQUEST=GetCapabilities&SERVICE=WMS");
$gmd_URL->appendChild($gmd_URLText);
$gmd_linkage->appendChild($gmd_URL);
More information about the Mapbender_commits
