[Mapbender-dev] Re: [SAC] Trac URLs
Arnulf Christl
arnulf.christl at wheregroup.com
Fri Feb 2 05:17:05 EST 2007
Howard Butler wrote:
> yes. I had to turn them off because it was causing the main website and
> other stuff to 403. I think once we get everything moved to virtual
> hosts instead of a single host, we'll be ok.
> /me waits for OSGeo Ottawa to finish their beers and come muck with the
> server ;)
> Howard
the Mapbender Project bug tracker still lives on SourceForge. In order to get threads back together we request for a substitute that is operated on *osgeo.org/* (* being references to "mapbender" and "trac" in whichever way you work out).
Take your time with the beer, there is no hurry and we will rather wait some longer until naming conventions are really settled.
Best regards,
Arnulf.
track.
> On Feb 1, 2007, at 4:06 PM, Robert Bray wrote:
>> These just stopped working...
>>> I implemented a virtual host called trac2.osgeo.org that provides the
>>> URL layout we want.
>>> http://trac2.osgeo.org/mapguide
>>> http://trac2.osgeo.org/fdo
>>> http://trac2.osgeo.org/osgeo
>>> http://trac2.osgeo.org/gdal
>>> I propose that we switch this over and create a real virtual host at
>>> http://trac.osgeo.org as soon as possible.
>>> Shawn, I did this by creating a virtual host in the
>>> conf.d/virtual_hosts.conf file, and in there I made an include for a
>>> trac directory, with *.conf files in there defining locations for
>>> each project. Additionally, all Trac instances in this layout are
>>> using mod_python, so they're much faster, and each is running off of
>>> the same internal Python interpreter (google for more info on why
>>> this is a recommended practice). When you're ready, you should just
>>> have to switch off the URL intercepting for trac.osgeo.org, update
>>> virtual_hosts.conf and restart and we'll be good to go. Can you take
>>> care of this?
>>> Howard
>>> On Feb 1, 2007, at 12:59 PM, Daniel Morissette wrote:
>>>> In the MapGuide IRC meeting today I saw 3 different URLs being used
>>>> to refer to the MapGuide Trac instance:
>>>> http://www.osgeo.org/trac/mapguide
>>>> http://mapguide.osgeo.org/trac/mapguide
>>>> http://trac.osgeo.org/trac/mapguide
>>>> If we agreed to use service-based URLs then I believe
>>>> http://trac.osgeo.org/trac/mapguide should be the official URL,
>>>> correct?
>>>> Shouldn't all the other ones be either removed or be redirects to
>>>> the master URL to avoid the confusion of having multiple URLs pulished.
>>>> Actually I think that http://trac.osgeo.org/mapguide would have been
>>>> even better, any reason why this is not what's been used?
>>>> Daniel
>>>> --Daniel Morissette
>>>> http://www.mapgears.com/
>>>> _______________________________________________
>>>> Sac mailing list
>>>> Sac at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/sac
>>> Sac mailing list
>> Sac mailing list
> Sac mailing list
More information about the Mapbender_dev
