[Mapbender-dev] [Mapbender] #134: the same javascript may be loaded twice in map.php
Mapbender info at osgeo.org
Tue Nov 6 11:54:38 EST 2007
 Reporter:  christoph  |       Owner:  mapbender_dev at lists.osgeo.org
     Type:  defect     |      Status:  new
 Priority:  major      |   Milestone:  2.5 release
Component:  core       |     Version:  2.4.3
 Keywords:             |
 map.php
 $mb_sql = "SELECT DISTINCT e_js_file, e_id, e_src, e_target, e_pos FROM
 gui_element WHERE e_public = 1 AND fkey_gui_id = $1 ORDER BY e_pos";
 $mb_v = array($_REQUEST["gui_id"]);
 $mb_t = array("s");
 $mb_res = db_prep_query($mb_sql, $mb_v, $mb_t);
 while($row_js = db_fetch_array($mb_res)){
         if($row_js["e_js_file"] != ""){
                 $e_id = $row_js["e_id"];
                 $e_id_css = $row_js["e_id"];
                 $e_src = $row_js["e_src"];
                 $e_target = $row_js["e_target"];
                 include($row_js["e_js_file"]);
 Maybe we could just replace the include by include_once?
 If we wanted to enable loading the same element multiple times, we would
 really need to change the architecture...
Ticket URL: <http://trac.osgeo.org/mapbender/ticket/134>
Mapbender <http://www.mapbender.org/>
More information about the Mapbender_dev mailing list
