[Mapbender-dev] development plans: TreeGDE 2.1
Christoph Baudson (WhereGroup) christoph.baudson at wheregroup.com
Wed Oct 31 04:54:01 EDT 2007
Hi Marc,
this sounds great.
I recommend setting up a work group for this, see
http://www.mapbender.org/index.php/Category:Workgroup. You might just
want to list the interested parties (sign me up) and link to the treeGDE
discussion page from there (unless you are planning a completely new
module).
We informally agreed upon using jQuery in the main frame. A formal
decision will follow soon.
Personally, I'm curious about the way you make use of jQuery. I have
never really used it a lot, and so my JS code always looks too
complicated when I interact with DOM.
I guess it will be very beneficial for the project. Thanks
Christoph
Marc Jansen schrieb:
> Hi list,
> while working with the "newer" TreeGDE 2 (which is way better than the
> old tree-module) we noticed some smaller disadvantages.
> We therefore want to start working on a TreeGDE 2.1-module which is
> based on the current TreeGDE 2-module. Please share your ideas and
> demands for a new version of the tree. As always no one guarantees
> desired functionality but sharing your thoughts might lead to a better
> realisation of the module.
> We want to change certain things (This are first ideas we are
> collecting):
>    * removal of tabular layout
>    * removal of invalid markup (id starting with numbers)
>    * better interactivity (defining custom callbacks?)
>    * AJAXify the tree ?
> Maybe we will have the ability to put some more functionality in the
> tree.  BTW: has the community agreed on putting jquery in the main frame?
> Feel free to share all your thoughts about this mild redesign on the
> list or within the wiki (I have not set up a page, I was unsure as to
> where this would fit best)
> Bye,
> Marc
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Where2B-Konferenz
Die Lösungskonferenz der WhereGroup
am 29. November 2007 in Bonn
http://www.where2b-conference.com
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 17
Fax: +49 (0)228 / 90 90 38 - 11
olaf.knopp at wheregroup.com
http://www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
More information about the Mapbender_dev mailing list
