[Mapbender-dev] development plans: TreeGDE 2.1
Marc Jansen jansen.marc at gmx.de
Wed Oct 31 07:07:58 EDT 2007
Hi Christoph,
hi Astrid,
hi list,
OK, a first draft is available under:
http://www.mapbender.org/index.php/Tree_GDE_2_redesign. I added this as
a discussion point for next weeks IRC meeting.
Christoph, I hope you're not too disappointed when you see "my usage" of
jquery :-) ... it's far less exciting than you might expect.
-- Marc
Christoph Baudson (WhereGroup) schrieb:
> Hi Marc,
> this sounds great.
> I recommend setting up a work group for this, see
> http://www.mapbender.org/index.php/Category:Workgroup. You might just
> want to list the interested parties (sign me up) and link to the
> treeGDE discussion page from there (unless you are planning a
> completely new module).
> We informally agreed upon using jQuery in the main frame. A formal
> decision will follow soon.
> Personally, I'm curious about the way you make use of jQuery. I have
> never really used it a lot, and so my JS code always looks too
> complicated when I interact with DOM.
> I guess it will be very beneficial for the project. Thanks
> Christoph
> Marc Jansen schrieb:
>> Hi list,
>> while working with the "newer" TreeGDE 2 (which is way better than the
>> old tree-module) we noticed some smaller disadvantages.
>> We therefore want to start working on a TreeGDE 2.1-module which is
>> based on the current TreeGDE 2-module. Please share your ideas and
>> demands for a new version of the tree. As always no one guarantees
>> desired functionality but sharing your thoughts might lead to a better
>> realisation of the module.
>> We want to change certain things (This are first ideas we are
>> collecting):
>>    * removal of tabular layout
>>    * removal of invalid markup (id starting with numbers)
>>    * better interactivity (defining custom callbacks?)
>>    * AJAXify the tree ?
>> Maybe we will have the ability to put some more functionality in the
>> tree.  BTW: has the community agreed on putting jquery in the main
>> frame?
>> Feel free to share all your thoughts about this mild redesign on the
>> list or within the wiki (I have not set up a page, I was unsure as to
>> where this would fit best)
>> Bye,
>> Marc
>> Mapbender_dev mailing list
>> Mapbender_dev at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
More information about the Mapbender_dev mailing list
