[Mapbender-dev] install script for windows? - links to cmd /
bat help pages
Christoph Baudson
christoph.baudson at wheregroup.com
Thu Jul 2 03:10:42 EDT 2009
Astrid Emde schrieb:
>>> msgfmt.exe should be installed on windows too. This tools comes with
>>> the
>>> installation of poedit. You only have to aff the path to msgfmt to the
>>> PATH variable.
>>> Please have a look at:
>>> http://www.mapbender.org/Gettext#Utility_programms
>>> It would be cool if this would be added to the script aswell.
>> ok, depending on temperature in my workroom i will add it tomorrow ;-)
>> Ciao
>> Thomas
> Hello Thomas,
> I hope your office cooled down a bit ;)
> I tested your script and it worked fine. I just tried it for
> * postgresql - UTF8
> * I had to add PostgreSQL to the PATH-Variable
> * I liked the way how the script leads through the installation
> Are the scripts from the workflow more or less the same? Or do we have
> to take parts from your changes to the install_2.6.sh script
> Well done!
I didn't test it, but thanks a lot for porting the script to Windows.
And thanks to everybody who worked on this script, it is an essential
part of Mapbender. Very much appreciated,
Christoph
> Astrid
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Treffen Sie uns auf der AGIT 2009, vom 8.-10. Juli in Salzburg!
Lassen Sie sich an Stand Nr. 30 über neue Entwicklungen
im Bereich WebGIS informieren!
www.agit.at
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_dev
