[Mapbender-dev] [gsoc09] Admininterface ideas
Astrid Emde
astrid.emde at wheregroup.com
Tue Jun 2 05:13:09 EDT 2009
Hello Karim,
I favorite your sketch B.
* menu with navigation from top with drop down
* lot of space underneath the navigation
Sounds very good to me like this.
You can handle the way how the admin gui look by css. We did something
similar for the login-page (see http://www.mapbender.org/GUI_Category)
Best regards astrid
karim@ schrieb:
> Dear List,
> I met with Christoph yesterday to discuss what the new admininterface for mapbender could look like.
> This is a summary of our discussion.
> I created two nonfunctional sketches to illustrate two ideas
> A) A more "function centric" view (see [1])
> This is similar to the admin2_.., so I won't explain much.
> The entries here are roughly grouped by functionality.
> After opening the desired function, the objects to operate on
> are selected.
> B) A more "object centric" view (see [2])
> This is what I came up with before digging into the depth of the mapbender code.
> The top menu (Users | WMS | WFS | GUI | Options) could be tabs,
> that select different modules. In the example "Users" is open
> (because it is very simple) to show the basic idea.
> WMS, WFS, GUI and Users all act similar in that there is a list of them,
> and each entry needs to be configured.
> The list on the left lists the entries, lets a user apply a simple filter on the name of the entry and
> links to the "add new <entry>".
> Clicking on a listentry opens it's configuration pages. In my example
> setting the username, password, etc. is done underneath the "core data"-tab
> and users rights could be assigned underneath the "rights"-tab.
> The desired object is selected first and the functionality exposed afterwards.
> These are just rough sketches, and now I am looking for ideas, questions and criticism
> from you to find out where I should be going.
> Seven, I recall you expressing interest in the userinterface design, I am very open to suggestions.
> Regards,
> Karim
> [1] http://karim.malhas.de/gsoc09/sketchA.html
> [2] http://karim.malhas.de/gsoc09/sketchB.xml
> Mapbender_dev mailing list
> Mapbender_dev at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_dev
Mit freundlichen Grüßen
Astrid Emde
Astrid Emde
WhereGroup GmbH & Co.KG
Siemensstraße 8
53121 Bonn
Germany
Fon: +49(0)228 90 90 38 - 19
Fax: +49(0)228 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
More information about the Mapbender_dev
