[Mapbender-dev] concurrent editing
Balázs Bámer
bamerbalazs at gmail.com
Fri Mar 6 09:28:13 EST 2009
Hi Christoph,
> Mapbender doesn't yet implement Lock or GetFeatureWithLock, but it would
> make sense, as your example above states. It should at least be a
> configurable option.
> If you plan to do some work on this field, we should talk about it and
> discuss where to add the necessary code.
I do not know yet what we will exactly do, but if solution for this
problem is necessary, I definitely will contact you.
Best regards: Balázs Bámer
More information about the Mapbender_dev
