[Mapbender-users] ConfTreeGde
Arnulf Christl
arnulf.christl at ccgis.de
Sun Apr 23 15:24:25 EDT 2006
On Wed, April 19, 2006 10:06, Antje Smit wrote:
> Using Mapbender 2.2.2, UMN 4.4.0, PHP Version 5.0.4, PostGreSQL 8.0.3 I
> get
> the followin error message:
> "Error: not valid capabilities document"
I do not understand the question?! The capabilties document is only
required during WMS upload and dynamic upload - how is this connected with
ConfTreeGDE?!
> I assume the problem is that there is no layer activated in the
> ConfTreeGde
> but I don't know how to set a checkbox using Mapbender 2.2.2.
You have to activate the corrsponding layer as query default. Then every
time you trigger a getFeatureInfo all alyers tagged as default will be
queried. This might look like an error but its not. The idea of
ConfTreeGDE ist to be able to merge several layers into one checkbox -
but then obviously there only one checkbox available per layer cluster
thus making it impossible to check or uncheck them individually.
Best regards,
Arnulf.
> With a normal TreeGde (Mapbender2.2.2) it is made in the Edit Gui Elements
> module and Mapbender 2.2.3 has the option to set a var_name
> checkbox_on_off
> but how can I do it using ConfTreeGde with Mapbender 2.2.2?
> Thanks,
> Anna
> http://www.nabble.com/ConfTreeGde-t1472969.html#a3983324
> Sent from the mapbender-users forum at Nabble.com.
> To unsubscribe, e-mail: users-unsubscribe at mapbender.osgeo.org
> For additional commands, e-mail: users-help at mapbender.osgeo.org
Arnulf Christl
http://www.ccgis.de
More information about the Mapbender_users
