[Mapbender-users] Re: PHP Error Messages
    Joscha Laubach
    laubach at iai.uni-bonn.de
    Fri Dec 21 08:28:27 EST 2007
Hi list,
I solved this problem by installing an older version of PHP. With PHP4
it works without any problems, with PHP5 (both: latest versions from
php.net) I get the described errors.
Is that a common bug? At least I didn't find anything about this problem
in Mapbenders bug tracker.
Regards,
Joscha
Joscha Laubach wrote:
> Hi list,
> I installed the new PHP5 version on Windows Server 2003 and IIS. PHP
> uses the ISAPI module. If I call phpinfo(), everything looks fine. But
> when I open my old Mapbender installation (2.4.3), I get several fatal
> errors like this one:
> Fatal error: Cannot redeclare auth_user() (previously declared in
> C:\Program Files\mapbender_2.4.3\http\frames\login.php:24) in C:\Program
> Files\mapbender_sld\http\frames\login.php on line 59
> Instead of auth_user() I also get db_escape_string() and others, so I
> guess it has something to do with the PHP configuration?
> Thanks and regards,
> Joscha
More information about the Mapbender_users
