[Mapbender-users] Re: PHP Error Messages
Christoph Baudson (WhereGroup) christoph.baudson at wheregroup.com
Fri Dec 21 08:59:03 EST 2007
Hi Joscha,
using PHP4 will not solve your problem, as some functionality in
Mapbender 2.4.3 requires PHP5.
 From Mapbender 2.4.2 onwards, PHP5 is required.
Sorry, I have no idea where the error stems from. Something to do with
using the SLD branch?
Christoph
Joscha Laubach schrieb:
> Hi list,
> I solved this problem by installing an older version of PHP. With PHP4
> it works without any problems, with PHP5 (both: latest versions from
> php.net) I get the described errors.
> Is that a common bug? At least I didn't find anything about this
> problem in Mapbenders bug tracker.
> Regards,
> Joscha
> Joscha Laubach wrote:
>> Hi list,
>> I installed the new PHP5 version on Windows Server 2003 and IIS. PHP
>> uses the ISAPI module. If I call phpinfo(), everything looks fine.
>> But when I open my old Mapbender installation (2.4.3), I get several
>> fatal errors like this one:
>> Fatal error: Cannot redeclare auth_user() (previously declared in
>> C:\Program Files\mapbender_2.4.3\http\frames\login.php:24) in
>> C:\Program Files\mapbender_sld\http\frames\login.php on line 59
>> Instead of auth_user() I also get db_escape_string() and others, so I
>> guess it has something to do with the PHP configuration?
>> Thanks and regards,
>> Joscha
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 25
Fax: +49 (0)228 / 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
More information about the Mapbender_users mailing list
