Antw: [Mapbender-users] MB 2.5: capabilities-upload does notwork
Verena Diewald
verena.diewald at wheregroup.com
Thu Apr 24 08:40:50 EDT 2008
Hi Tilo,
I tried it with http://www.lv-bw.de/dv/capabilities-esri-testuser.xml and got
the same error you described in your mail, then I tested it with
https://www.lv-bw.de/dv/capabilities-esri-testuser.xml and everything worked
fine.
Greetings
Verena
Am Donnerstag 24 April 2008 13:50:28 schrieb Tilo Wutherich:
> Hi Ronald,
> > I don't know exactly what's your problem but i just loaded a
> > geserver-1.6.3 Capabilities-Document
> > in a current MB 2.5 rc installation and it works fine.
> Mapbender complains about some "Missing parameters" and does not upload the
> data. But some of the params are definitly in the cap-doc and MB 2.4.2 does
> not complain at all. Maybe someone of the Wheregroup-team knows some help?
> Greetings,
> Tilo
> > > http://<a_local_ip>:8080/geoserver/geoserver.xml
> > > returns:
> > > Missing parameters:
> > > id:
> > > version: 1.1.1
> > > title: VM Jupiter GeoServer KlosterDB
> > > abstract: This is a description of your Web Map Server.
> > > maprequest:
> > > capabilitiesrequest:
> > > featureinforequest:
> > > gui_wms_mapformat:
> > > gui_wms_featureinfoformat:
> > > gui_wms_exceptionformat:
> > > gui_wms_epsg:
> > > wms_srs:
> > > gui_wms_visible: 1
> > > gui_wms_opacity: 100
> > > support_sld: 0
> > > id: parent: name: title: queryable: 0 minScale: 0 maxScale: 0
> > > dataurl:
> > > metadataurl:
> > > layerstyle:
> > > name title legendurl legendurlformat
> > > Data not commited
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
More information about the Mapbender_users
