Antw: [Mapbender-users] MB 2.5: capabilities-upload does notwork
Michael Schulz mschulz at webgis.de
Thu Apr 24 08:52:38 EDT 2008
Hi Tilo,
it seems, the LV-BW server is a little bit exhausted? I just tried the
requests via wget and the http request gets repeatedly "connection
reset by peer" ... Don't know why though, but wget tries to reconnect
and succeeds after several tries, mapbender won't do that i assume.
The https request doesn't suffer from this.
wget output:
# wget http://www.lv-bw.de/dv/capabilities-esri-testuser.xml -O /tmp/lvhttp.xml
--15:17:41--  http://www.lv-bw.de/dv/capabilities-esri-testuser.xml
           => `/tmp/lvhttp.xml'
Resolving www.lv-bw.de... 193.197.148.76
Connecting to www.lv-bw.de|193.197.148.76|:80... connected.
HTTP request sent, awaiting response... Read error (Connection reset
by peer) in headers.
Retrying.
--15:17:42--  http://www.lv-bw.de/dv/capabilities-esri-testuser.xml
  (try: 2) => `/tmp/lvhttp.xml'
HTTP request sent, awaiting response... 200 OK
Length: 5,426 (5.3K) [text/xml]
100%[===============================================================>]
5,426         --.--K/s
15:17:42 (56.64 KB/s) - `/tmp/lvhttp.xml' saved [5426/5426]
Cheers, Michael
2008/4/24 Verena Diewald <verena.diewald at wheregroup.com>:
> Hi Tilo,
>  I tried it with http://www.lv-bw.de/dv/capabilities-esri-testuser.xml and got
>  the same error you described in your mail, then I tested it with
>  https://www.lv-bw.de/dv/capabilities-esri-testuser.xml and everything worked
>  fine.
>  Greetings
>  Verena
>   Am Donnerstag 24 April 2008 13:50:28 schrieb Tilo Wutherich:
> > Hi Ronald,
>  > > I don't know exactly what's your problem but i just loaded a
>  > > geserver-1.6.3 Capabilities-Document
>  > > in a current MB 2.5 rc installation and it works fine.
>  > Mapbender complains about some "Missing parameters" and does not upload the
>  > data. But some of the params are definitly in the cap-doc and MB 2.4.2 does
>  > not complain at all. Maybe someone of the Wheregroup-team knows some help?
>  > Greetings,
>  > Tilo
>  > > > http://<a_local_ip>:8080/geoserver/geoserver.xml
>  > > > returns:
>  > > > Missing parameters:
>  > > > id:
>  > > > version: 1.1.1
>  > > > title: VM Jupiter GeoServer KlosterDB
>  > > > abstract: This is a description of your Web Map Server.
>  > > > maprequest:
>  > > > capabilitiesrequest:
>  > > > featureinforequest:
>  > > > gui_wms_mapformat:
>  > > > gui_wms_featureinfoformat:
>  > > > gui_wms_exceptionformat:
>  > > > gui_wms_epsg:
>  > > > wms_srs:
>  > > > gui_wms_visible: 1
>  > > > gui_wms_opacity: 100
>  > > > support_sld: 0
>  > > > id: parent: name: title: queryable: 0 minScale: 0 maxScale: 0
>  > > > dataurl:
>  > > > metadataurl:
>  > > > layerstyle:
>  > > > name      title   legendurl       legendurlformat
>  > > > Data not commited
>  > _______________________________________________
>  > Mapbender_users mailing list
>  > Mapbender_users at lists.osgeo.org
>  > http://lists.osgeo.org/mailman/listinfo/mapbender_users
Michael Schulz
in medias res
Gesellschaft für Informationstechnologie mbH
In den Weihermatten 66
79108 Freiburg
Tel +49 (0)761 556959-5
Fax +49 (0)761 556959-6
http://www.webgis.de / http://www.zopecms.de
More information about the Mapbender_users mailing list
