Antw: [Mapbender-users] MB 2.5: capabilities-upload does notwork
Tilo Wütherich tilo.wuetherich at la-bw.de
Thu Apr 24 09:00:37 EDT 2008
Hi Verena,
> I tried it with
> http://www.lv-bw.de/dv/capabilities-esri-testuser.xml and got
> the same error you described in your mail, then I tested it with
> https://www.lv-bw.de/dv/capabilities-esri-testuser.xml and
> everything worked fine.
thank you for your help. I got this also working. The problem to me is, that
my last working setup is mapbender 2.4.2 and geoserver 1.5.4. Since MB 2.4.3
it does not work with geoserver 1.5.4 cap.-docs.
Cheers,
Tilo
More information about the Mapbender_users mailing list
