[Mapbender-users] PDF-Print and Symbols
Tilo Wütherich tilo.wuetherich at la-bw.de
Tue Mar 25 09:59:23 EDT 2008
Hello,
> This solution is a workaround and is only defined for UMN mapfiles at
> the moment. If you use GeoServer you could implement a similar solution
> with a second WMS which uses different styles like described above.
unfortunately I am using geoserver. I think I can't define a second WMS and
even if I define another datastore and feature type, geoserver remembers
that the source is already in use and shows it as an error in the
admin-gui...
Greetings,
Tilo
More information about the Mapbender_users mailing list
