[Mapbender-users] [Fwd: Cannot load WMS through admin2_en or admin_en_services]
Arnulf Christl arnulf.christl at wheregroup.com
Fri May 23 04:05:53 EDT 2008
Forwarded to list address (original sent to: mapbender_users-owner at lists.osgeo.org)
-------- Original Message --------
Subject: Cannot load WMS through admin2_en or admin_en_services
Date: Thu, 22 May 2008 15:11:28 +0300
From: Angel Nedelchev <angel.nedelchev at gmail.com>
To: mapbender_users-owner at lists.osgeo.org
Sear List
I am running Mapbender Version 2.4.3 (2007-10-05)  with correctly installed
PostgreSQL and Postgis on Windows version of Mapserver ms4w version 2.2.7
Everything seems to work fine.
But in fact is not.
When I try load WMS from button "Adding WMS" on GUI (front end) its OK. WMS
layers loads.But this way loads WMS temporary.
But when I try to load WMS permanently through "admin2_en" or
"admin_en_services" from back end i receive the following error message
*Warning*: pg_exec() [function.pg-exec]: Query failed: ERROR: duplicate key
value violates unique constraint "pk_gui_layer" in *
C:\ms4w\apps\mapbender\http\php\database-pgsql.php* on line *133*
sql error: ERROR: duplicate key value violates unique constraint
"pk_gui_layer" ROLLBACK performed....
Can you help me, dear list.
Angel
More information about the Mapbender_users mailing list
