AW: AW: AW: [Mapbender-users] MB 2.5: Error in saveWMC / loadWMC
Schönhammer, Herbert
Schoenhammer.Herbert at Regensburg.de
Tue Nov 4 07:58:36 EST 2008
Hello,
sorry for the second reply:
The description of the libxml-package version 2.6.23 installed on "my" server sais:
The XML C library was initially developed for the GNOME project. It is now used by many programs to load and save extensible data structures or manipulate any kind of XML files.
This library implements a number of existing standards related to markup languages, including the XML standard, namespaces in XML, XML Base, RFC 2396, XPath, XPointer, HTML4, XInclude, SGML catalogs, and XML catalogs. In most cases, libxml tries to implement the specification in a rather strict way. To some extent, it provides support for the following specifications, but does not claim to implement them: DOM, FTP client, HTTP client, and SAX.
The library also supports RelaxNG. Support for W3C XML Schemas is in progress.
Greetings
Herbert Schoenhammer
>-----Ursprüngliche Nachricht-----
>Von: mapbender_users-bounces at lists.osgeo.org
>[mailto:mapbender_users-bounces at lists.osgeo.org] Im Auftrag
>von Christoph Baudson
>Gesendet: Dienstag, 4. November 2008 13:44
>An: Mapbender User List
>Betreff: Re: AW: AW: [Mapbender-users] MB 2.5: Error in
>saveWMC / loadWMC
>Thanks for your reply. My PHP installation lists the DOM
>library as follows
>dom
>DOM/XML enabled
>DOM/XML API Version 20031129
>libxml Version 2.6.30
>HTML Support enabled
>XPath Support enabled
>XPointer Support enabled
>Schema Support enabled
>RelaxNG Support enabled
>I'm using PHP 5.2.3. What PHP version are you using? What is
>your server OS?
>Thanks
>Christoph Baudson
>Schönhammer schrieb:
>> Hello Christoph, hello Mr. Scholle,
>> phpinfo() does NOT list a DOM-library.
>> Reading the doc's in
>http://de2.php.net/manual/de/dom.setup.php no specail library
>should be installed. Only the php-xml module should be installed.
>> phpinfo() says:
>> php Version 5.2.5
>> configure-Settings are: ..., '--enable-libxml'...
>'--enable-xml' '--enable-simplexml' ...
>> libXML Support: active
>> libXML Version 2.6.23
>> libXML streams: enabled
>> greetings
>>> Gesendet: Dienstag, 4. November 2008 12:54
>>> Betreff: Re: AW: [Mapbender-users] MB 2.5: Error in saveWMC
>/ loadWMC
>>> Hello,
>>> do you have the DOM library installed in PHP? Just check
>via phpinfo().
>>> Christoph Baudson
>>>> Hello Mr. Scholle,
>>>> thank you for your reply.
>>>> I'm using SLES10 as Server-OS. That's fix, my IT wants this server.
>>>> I've tried now FF 3.x, IE7 and now the latest Opera. It's
>>> all the same.
>>>> But I had just a look in the webserver error_log. I get
>the following
>>>> error-message when saving the the wmc:
>>>> PHP Fatal error: Class 'DOMDocument' not found in
>>>> /home/mapbender/mapbender_2.5/http/classes/class_wmc.php
>on line 239
>>>> Will a developper or something else have a tipp for further
>>> "researches" ?
>>>> Thanks
>>>> *Von:* mapbender_users-bounces at lists.osgeo.org
>>>> [mailto:mapbender_users-bounces at lists.osgeo.org] *Im Auftrag von
>>>> *Burghardt.Scholle at stadt.wolfsburg.de
>>>> *Gesendet:* Dienstag, 4. November 2008 08:37
>>>> *An:* mapbender_users at lists.osgeo.org
>>>> *Betreff:* AW: [Mapbender-users] MB 2.5: Error in saveWMC / loadWMC
>>>> Hello Mr. Schönhammer,
>>>> I still have the same problems in a system combination
>>> with Ubuntu
>>>> 8.04 (Server) and the IE6 (Client). With FF or IE7 I don't have
>>>> any Problems. In a system combination Debian
>Etch/Lenny (Server)
>>>> and any Browser I don't have any problems with
>save/load WMC too.
>>>> Perhaps you can try another combination to test the behavior of
>>>> the module mod_savewmc.php. Unfortunately I don't know
>a solution
>>>> for the first combination.
>>>> Greetings
>>>> Burghardt Scholle
>>>> [mailto:mapbender_users-bounces at lists.osgeo.org]*Im Auftrag
>>>> von *Schönhammer, Herbert
>>>> *Gesendet:* Dienstag, 4. November 2008 08:16
>>>> *Betreff:* [Mapbender-users] MB 2.5: Error in
>>> saveWMC / loadWMC
>>>> Hi list,
>>>> I want to generate a WMC-Document with MB 2.5 using
>>> the module
>>>> mod_savewmc.php.
>>>> Clicking the button "Save workspace as Web Map Context
>>>> Document" I am asked for the name of the workspace.
>>>> And that was all.
>>>> The wmc-document ist not offered using module
>>> mod_loadwmc.php.
>>>> MapBender does not create an entry in mb_error_logs.
>>>> I don't find any record in the table mb_user_wmc
>or any file
>>>> on the server or an my client.
>>>> I have tried all combinations with the var saveInSession:
>>>> - the var was set / unset
>>>> - the var was filled with the values 0/1
>>>> - the var was filled with the values true/false
>>>> The behaviour is reproducable with the shipped guis
>>> gui1 and gui2.
>>>> Where is the problem ?
>>>> Has anybody a solution for me ?
>>>> Greetings
>>>> Schönhammer Herbert
>>>> _______________________________________________
>>>> Mapbender_users mailing list
>>>> Mapbender_users at lists.osgeo.org
>>>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
>>> Where2B-Konferenz
>>> Die Geo-IT Konferenz der WhereGroup
>>> vom 9.-10. Dezember 2008 in Bonn
>>> Web: www.where2b-conference.com
>>> W h e r e G r o u p GmbH & Co. KG
>>> Siemensstraße 8
>>> 53121 Bonn
>>> Germany
>>> Christoph Baudson
>>> Anwendungsentwickler
>>> Fon: +49 (0)228 / 90 90 38 - 15
>>> Fax: +49 (0)228 / 90 90 38 - 11
>>> christoph.baudson at wheregroup.com
>>> www.wheregroup.com
>>> Amtsgericht Bonn, HRA 6788
>>> Komplementärin:
>>> WhereGroup Verwaltungs GmbH
>>> vertreten durch:
>>> Olaf Knopp, Peter Stamm
>Where2B-Konferenz
>Siemensstraße 8
>53121 Bonn
>Germany
>Christoph Baudson
>www.wheregroup.com
>Komplementärin:
>vertreten durch:
More information about the Mapbender_users
