[Mapbender-users] Re:Re: problems in loading a mapserver-WMS to
mapbender
Albrecht Weiser
AWeiser at gmx.de
Wed Feb 18 02:56:19 EST 2009
Hi Astrid,
that simple life can be :o) You're right - in my request i already used slashes, but in the mapfile i had backslashes for the reference to the mapfile.Many thanks.
Bye
Albrecht
> Hello Albert,
> please change the WMS_ONLINERESOURCE in your mapfile. Always use / .
> WMS_ONLINERESOURCE
> "http://www.xxx.info/cgi-bin/mapserv?map=D:/ms4w/Apache/htdocs/maps/bplan.map"
> Please check first whether you get an xml as response from the MapServer:
> http://www.xxx.info/cgi-bin/mapserv?map=D:/ms4w/Apache/htdocs/maps/bplan.map&service=WMS&request=GetCapabilities
> Then you can load the WMS in Mapbender
> Best regards Astrid
> On Mon, February 16, 2009 6:20 pm, Albrecht GMX wrote:
> > Hi mapbender list,
> > i'm just a newbie in using mapbender (but sooner or later it had to
> > come ;o)
> > I was just trying to load a WMS into my newly created gui. With
> > geoserver-WMS it was no problem. But when loading my UMN mapserver-WMS,
> > i've got an error from mapserver. Here's the error: "
> > msLoadMap(): Unable to access file.
> > (D:ms4wApachehtdocsmapsplan.map) ". As you might see,
> > mapbender removed all backslashes of the URL. Formerly the URL
> > was
> href="http://www.xxx.info/cgi-bin/mapserv?map=D:\ms4w\Apache\htdocs\maps\bplan.map&service=WMS&request=GetCapabilities">http://www.xxx.info/cgi-bin/mapserv?map=D:\ms4w\Apache\htdocs\maps\bplan.map&service=WMS&request=GetCapabilities</a> (i
> > don't know, if the messages are posted somewhere on the www, so i
> aliased
> > the url - if someone want to know, i can send the url personally via
> > email). Uploading the URL in the <a class=rvts10
> href="http://localhost/mapbender/frames/index.php?&gui_id=admin_de_services">admin_de_services</a><span
> > class=rvts8> was successful. Mapbender showed the capabilities
> found.
> > Only later, when testing to show the map in the gui, i received the
> error.
> > Does somebody know, what's wrong here?
> > <span class=rvts8>Thanks at all
> > Albrecht
Jetzt 1 Monat kostenlos! GMX FreeDSL - Telefonanschluss + DSL
für nur 17,95 Euro/mtl.!* http://dsl.gmx.de/?ac=OM.AD.PD003K11308T4569a
More information about the Mapbender_users
