[Mapbender-users] How to get mb_myBBOX to work
Astrid Emde (WhereGroup)
astrid.emde at wheregroup.com
Tue Feb 24 03:02:26 EST 2009
Albrecht Weiser schrieb:
> Hi mapbender list,
> i wanted to start my mapbender gui with an initial extent. I was reading to use "setBBOX". So i went to the GUI element administration and turned setBBOX on. I set the element ON/OFF to "1" to activate it. Then i tried to set the parameter "mb_myBBOX=", but which element i have to use? I tried the Attributes, Content, Requires, URL and SRC element in the GUI elements administration. i tried with "&setBBOX=" and with "setBBOX". I tried with native SRS-coordinates (Gauss-Krüger) and with WGS84. Nothing worked. Could somebody please tell me, how to fix that?
> Thanks
> Albrecht
Hello Albrecht,
have a look at the wiki-documentation
http://www.mapbender.org/SetBBOX
Here is an example
http://wms1.ccgis.de/mapbender2/frames/login.php?name=ccgis_de&password=ccgis_de&mb_user_myGui=MiddleAmerica&mb_myBBOX=-102.92,11.56,-86.37,25.07
Best regards Astrid
More information about the Mapbender_users
