AW: [Mapbender-users] Getting info on layer status, selected or not?
Kesting, Arne Arne.Kesting at velbert.de
Wed Feb 25 05:30:19 EST 2009
Hi Christoph,
thanks for the detailed advice. I will try it and have a look at map.js and map_obj.js.
Mit freundlichen Grüßen
Arne Kesting
Stadt Velbert
Technische Verwaltungsdienste
Geodaten und Vermessung
Am Lindenkamp 31, Raum 228
42549 Velbert
Tel.: 02051/26-2647
Fax: 02051/26-2784
Email: arne.kesting at velbert.de
Internet: http://www.velbert.de
-----Ursprüngliche Nachricht-----
Von: mapbender_users-bounces at lists.osgeo.org [mailto:mapbender_users-bounces at lists.osgeo.org] Im Auftrag von Christoph Baudson
Gesendet: Mittwoch, 25. Februar 2009 11:21
An: Mapbender User List
Betreff: Re: [Mapbender-users] Getting info on layer status, selected or not?
Hi Arne,
Kesting, Arne schrieb:
> Hello,
> this is the problem:
> I want to adjust the pdf print output according to the layer which is
> currently selected.
> Here is a small example.
> If layer A is selected i want to write text1 into the mapframe (pdf
> output) an if layer B is selected,
> please write text2 into the mapframe.
> How can i get the status or info of a specific layer? Is it
> selected(on) or not (off)?
> Everything should be implemented into an already user-defined
> mod_printPDF_pdf.php file.
> I don't know how to access the above mentioned information about the
> layers.
> Thanks for any help on this topic.
This will be a bit tricky. You would need to send the status information of your layers to the server side PHP.
The layers are stored in a wms object, which itself is stored in a map object. The layer attribute you want to query is "gui_layer_visible".
Assume you know the name of your map , which is presumably "mapframe1", the WMS ID in the database (let's say, 543), and the layer name
("myLayerName") here's a JavaScript code snippet.
var layer = mb_getLayerObjByName("mapframe1", 543, "myLayerName");
You'll find the function in map.js. Take a look at the file in order to learn more. You might also want to take a look at map_obj.js, where the wms and layer object are defined. You can retrieve the attribute like this
var myLayersVisibility = layer.gui_layer_visibile;
You could then set the value a hidden form field to myLayersVisibility, and by this, send it to the server side.
This is all a bit awkward, as the print module doesn't yet use AJAX. I hope this helps at least a bit.
Christoph
> best regards
> Arne Kesting
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
 FOSSGIS Konferenz 2009
 17.-19. März 2009 in Hannover
 http://www.fossgis.de/konferenz
_______________________________________
W h e r e G r o u p GmbH & Co. KG
Siemensstraße 8
53121 Bonn
Germany
Christoph Baudson
Anwendungsentwickler
Fon: +49 (0)228 / 90 90 38 - 15
Fax: +49 (0)228 / 90 90 38 - 11
christoph.baudson at wheregroup.com
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_users mailing list
