[Mapbender-users] Mapbender recognizes wrong SRS of my geoserver-WMS
Astrid Emde (WhereGroup) astrid.emde at wheregroup.com
Wed Feb 25 13:26:08 EST 2009
Hello Albert,
please check whether your Mapbender has PostGIS support (the Mapbender
PostgreSQL database needs the postgis functions).
For changing the EPSG we need the PostGIS function transform.
Maybe this is the problem
Best regards
Astrid
On Wed, February 25, 2009 12:27 pm, Albrecht Weiser wrote:
> Hi mapbender list,
> today i post a strange behaviour of my mapbender. I wanted to add a
> geoserver WMS to my mapbender WMS-URL's. When creating a separate gui from
> that, the initial SRS of the gui is epsg:4326. When i want to change to
> the native SRS of the WMS (which is epsg:31467), the gui says "undefined".
> But that's not true, because the only SRS defined in this WMS is
> epsg:31467. That's a problem, because i want to overlay a WMS with a
> topo-map from remote and thats in epsg:31467 too. If i want to load both
> layers, i get an error: all layers must be in the same SRS.
> But when i test the WMS with the test-mapbender from
> http://mapbender.telascience.org, then the service is being correctly
> bound as epsg:31467 (i can also switch to 4326 or 31466 even though these
> SRS aren't defined in my WMS - weird thing!).
> It means, my mapbender-settings are faulty somewhere.
> Does somebody have an idea where to search?
> Thanks
> Albrecht
> Psssst! Schon vom neuen GMX MultiMessenger gehört? Der kann`s mit allen:
> http://www.gmx.net/de/go/multimessenger01
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
Mit freundlichen Grüßen
Astrid Emde
 FOSSGIS Konferenz 2009
 17.-19. März 2009 in Hannover
 http://www.fossgis.de/konferenz
  Astrid Emde
  WhereGroup GmbH & Co.KG
  Siemensstraße 8
  D-53121 Bonn
  Fon: +49(0)228 90 90 38 - 19
  Fax: +49(0)228 90 90 38 - 11
  http://www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Olaf Knopp, Peter Stamm
More information about the Mapbender_users mailing list
