[Mapbender-users] how to activate module SwitchLocale_noreload
Astrid Emde (WhereGroup)
astrid.emde at wheregroup.com
Tue Jan 27 02:45:33 EST 2009
Peter Freimuth schrieb:
> Hi list,
> i searched at the wiki pages but i cannot find any useful informations
> about how to activate the locale selection in a gui.
> Further we need informations about how to create new localisations
> (spanish, portuguese and others).
> How can we create tooltips for the different standard buttons in
> different languages so that they change when we switch the locale?
> How can we define a default locale for a gui?
> Thanks for any hints on how to solve these issues!
> Kind regards,
> Peter
Hello Peter,
information about Mapbender internationalisation you can find at [1]
Information about SwitchLocale_noreload you can find at [2].
In the mapbender.conf you can define a LANGUAGE variable as default
language. This information is also saved in the session-file as
$_SESSION["mb_lang"].
To create new languages you have to do twoi things:
1. add the new language entries to the table mb_translations (this is
used for toolstips and the titles of the div tags)
2. create a new .po file (this is used for the translations of the
modules (f.e. the print module). Have a look at [3].
3. check the file classes/class_locale.php - make sure that you locale
is refered here. Compile the .mo file
There are already translations for some languages (Table translations:
bg,de,es,gr,it,nl / po-files for bg,de,fr,gr,it). If you do some more
translations, it would be nice, if you could give your translations back
to the Mapbender project so we could integrate them to the code.
[1] http://www.mapbender.org/Category:I18n
[2] http://www.mapbender.org/SwitchLocale_noreload
[3] http://www.mapbender.org/Gettext
Best regards
Astrid Emde
FOSSGIS Konferenz 2009
17.-19. März 2009 in Hannover
http://www.fossgis.de/konferenz
Astrid Emde
WhereGroup GmbH & Co.KG
Siemensstraße 8
53121 Bonn
Germany
Fon: +49(0)228 90 90 38 - 19
Fax: +49(0)228 90 90 38 - 11
www.wheregroup.com
Amtsgericht Bonn, HRA 6788
Komplementärin:
WhereGroup Verwaltungs GmbH
vertreten durch:
Arnulf Christl, Olaf Knopp, Peter Stamm
More information about the Mapbender_users
