[Mapbender-users] Re: How to get mb_myBBOX to work
    bkswebgis
    walter.b at bodemann.com
    Wed Feb 24 10:36:31 EST 2010
I am new on this forum and new on experimenting with mapbender.
After some really nice successful tests I run into exactly the same problem.
Spending hours and hours I now need some help, as I'm really frustrated.
I've read all mails in forums and tested all the sample links .... all of
that is not working.
installed mapbender version: 2.6
I first call the osm map from a wms service and then the shapefiles from the
local mapserver.
Everything works fine but at startup I always see the extens of the world
map, even if I use the parameters ...&mb_myBBOX=9,47,11,49. setBBOX in gui
is on.
Does anyone have a solution for this problem, up to now I only found tips
but none answered problem solved!?
Where can I find the extents in the mapbender database (tablename,
fieldname)?
Thnak's for helping!
Walter
View this message in context: http://n2.nabble.com/How-to-get-mb-myBBOX-to-work-tp2364439p4626510.html
Sent from the mapbender-users mailing list archive at Nabble.com.
More information about the Mapbender_users
