[Mapbender-users] Re: Mapbender 2.7.1 and GeoServer 2.0.3 -
Connection Problem
roy
michele.rocc at gmail.com
Mon Apr 25 05:11:57 EDT 2011
Hi Seb,
i'm not so skilled on Mapbender but i managed to load some data on a gui,
maybe you didn't configure a symbology for the data you're loading (?),
if you can briefly summarize your configuration steps maybe
someone can see where the problem is ...
2011/4/25 sebweller <sebweller at web.de>
> So, one step for, two steps back...
> I've got another problem. I'm pretty sure ther will be no answer anyway...
> The wms connection seems to work. I can add layers and layergroups to every
> gui i want. the only problem is, i just get a white window... no maps are
> shown in the window, while i can select them. The GeoServer Layerpreview in
> OpenLayers works fine for those shapefiles...
> The Error Log Says:
> 2011.04.25, 11:22:58,ERROR: connector: unable to load:
> http://localhost/mapbender/javascripts/map.php/../../php/mod_getServiceDisclaimer.php?resource=wms&id=916&languageCode=de&asTable=true
> So, I still hope for your help...
> regards
> Sebastian
> http://osgeo-org.1803224.n2.nabble.com/Mapbender-2-7-1-and-GeoServer-2-0-3-Connection-Problem-tp6293465p6302324.html
> Sent from the mapbender-users mailing list archive at Nabble.com.
> Mapbender_users mailing list
> Mapbender_users at lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/mapbender_users
URL: http://lists.osgeo.org/pipermail/mapbender_users/attachments/20110425/ab6db786/attachment.html
More information about the Mapbender_users
