[Mapbender-users] Update WMS from geoserver misbehaviour
Marc Manns
marcmanns at gmx.de
Sat Jun 25 06:21:32 EDT 2011
Hi Albert,
one more question.
You're using Geoserver WMS.
Did you defined sld's and connected them with a gui layer ?
Marc
Am 24.06.2011 10:44, schrieb Astrid Emde:
> Hello Albert,
> thanks for the report of the WMS update problem. I never had such a
> problem before.
> It would be a big help, if you could send the getCapabilities-Request or
> send the Capabilities-XML to test the update.
> Astrid
> On Thu, June 23, 2011 1:01 pm, Albert Polze wrote:
>> Setup: mapbender: 2.7.1 ; geoserver: 2.1.0 ; Debian 6.0
>> Hello List
>> I would like to report a problem while updating a wms. After updating
>> some layers are missing in WMS application setting and GUIs.
>> In my environment I use 3 GUIs, each with one WMS from geoserver (stored
>> in a wms container). The WMS contains 7 Layers (1 raster, 6 vector loaded
>> in geoserver from disk). Everything worked like it should.
>> Now I added one of these vector layer into pstgres/postgis database and
>> loaded it into geoserver (with the same name but different store). After
>> some time (..serveral hours).. working with the data successfully
>> (including
>> serveral updates of the wms with no error) the WMS application setting
>> shows me:
>> GUI1: everything is good
>> GUI2 / 3 / wms container: only 3 of 8 layer are shown
>> When I open the GUIs:
>> GUI2 / 3: only these 3 of 8 layer are shown
>> In GUI3 I build in a search (gazetterWFS) for the layer from the database
>> the odd thing is although the layer is not represented in the WMS
>> application settings and the GUI I can successfully use the search on
>> this layer.
>> No errors in mb_error.log, php_error.log, geoserver-error-log. After
>> deleting the WMS completely and loading it up again it works fine.
>> Updating
>> the WMS again doesn't work.
>> I also got this behaviour with mapbender_2.6.2, geoserver-2.0.2, ubuntu
>> 10.04 as a localhostsystem.
>> I would provide further information (if needed).
>> Hallo Liste,
>> mir ist zum wiederholten male ein Problem untergekommen zu dem ich keine
>> Erklärung fand. Nach einem update meines WMS finden sich in meinen WMS
>> Anwedungseinstellungen und GUIs nicht alle Layer wieder.
>> Ich benutze 3 GUIs mit dem selben WMS vom geoserver. Der WMS wurde in
>> meinen wms-container hochgeladen und von dort in die GUIs verteilt, er
>> beinhaltet (1 Rasterlayer und 6 Vektorlayer die vom Verzeichnis aus in
>> geoserver geladen wurden). Alles funktionierte so wie es sollte.
>> Als nächstes habe ich einen der Vektorlayer unter einem anderen
>> Datastore
>> via postgres/postgis Datenbank in den geoserver geladen. Auch hier keine
>> Probleme. Nach ein paar Stunden und mehrmaligen aktualisieren des WMS
>> (alles
>> ohne Probleme) passierte folgendes:
>> WMS Anwendungseinstellungen:
>> GUI1: alles in Ordnung, so wie es sein sollte
>> GUI2 / 3 / wms container: nur 3 von 8 Layer werden angezeigt
>> geöffnete GUIs: GUI1: alles in Ordnung, so wie es sein sollte
>> GUI2 / 3: nur die 3 Layer werden angezeigt
>> In der GUI3 habe ich eine Abfrage (gazetterWFS) für den Layer aus der
>> Datenbank eingebaut. Merkwürdigerweise kann ich an dem Layer erfolgreich
>> Abfragen ausführen obwohl er für diese GUI weder in der WMS
>> Anwendungseinstellung noch in der GUI selber zu sehen ist.
>> Keine Fehler im mb_error.log, php_error.log, geoserver-error-log. Nachdem
>> ich den WMS vollsändig gelöscht, neu geladen und zugewiesen habe
>> funktioniert auch wieder alles. Erneutes updaten des WMS bringt nichts.
>> Ich hatte dieses Problem auch schonmal unter mapbender_2.6.2,
>> geoserver-2.0.2, ubuntu 10.04 (als localhostsystem)
>> Wenn noch informationen fehlen würde ich sie hier reinstellen. (Obwohl
>> ich hoffe das das Problem nicht wieder auftritt.
>> Grüße
>> View this message in context:
>> http://osgeo-org.1803224.n2.nabble.com/Update-WMS-from-geoserver-misbehav
>> iour-tp6508227p6508227.html Sent from the mapbender-users mailing list
>> archive at Nabble.com. _______________________________________________
>> Mapbender_users mailing list
>> Mapbender_users at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/mapbender_users
More information about the Mapbender_users
